Home > Technical > Steering Damper
The Hulk
Scotland 1997 Defender 110 300 Tdi HT Aintree Green
Steering Damper
Does anyone have one of these?
Mine was completely unsecured at one end and the bracket was fouling the holes in the steering guard
I've meantime removed it and I'm assuming it's not essential to the operation of the steering? It still steers ok anyway and has actually stopped wobbling like there's an unbalanced wheel! The 90 has one which looks just like a standard shock-absorber.
Does anyone know why this has a separate bracket rather than being bolted directly to the chassis bracket? And should I bother replacing it? Shocked Mid Life; Live It!
Ongoing thread: http://www.defender2.net/forum/topic45697.html
110 300Tdi Utility (Hulk)
90 300Tdi SW (GF's Tank)
Post #541904 20th Jun 2016 8:22pm
Green Machine
It's called a 'return to centre' or RTC steering damper. The idea is that the coil spring around the damper gives a centring force, causing the steering to have a more positive 'straight ahead' feeling and the steering to self-centre faster. General consensus seems to be that they are a complete waste of time and can lead to some strange handling characteristics. Never tried one myself. Can't really tell from your pictures what's going on with the brackets, but can't see any reason why it's not just attached to the standard steering damper brackets.
You should have a steering damper fitted, which does what it says on the tin - takes the 'kick' out of the steering. Various upgrade items are available including the one you have, along with offerings from Bilstein and Old Man Emu, but many say that the standard damper is perfectly adequate. 2005 Td5 | 90 Station Wagon | Tonga Green
Post #541928 20th Jun 2016 9:06pm
300TDi CSW Phil
United Kingdom 1995 Defender 110 300 Tdi CSW Epsom Green
Fitted one to mine last week as part of a suspension upgrade session.
Fits to the normal chassis bracket at the end that you appear to have a seperate bracket.
No issues whatsoever with it and much prefer the handling now. 1995 300 Tdi Epsom Green - It's a keeper.
Wide Track Sankey- In bits- Gone to a new home
M0XQS
Post #541944 20th Jun 2016 10:06pm
Looks like the mounting is non standard or bent?
Maybe it's just me!
I considered one of those once but decided against it, just stick to OE as it doesn't do much anyway to be honest other than as described above.
Post #541947 20th Jun 2016 10:23pm
williamthedog
That happened to my original steering damper a while back.
Detached itself from the chassis mount, not nice.
Post #541960 21st Jun 2016 5:09am
The Hulk
Maybe it's just me!
No, it's not just you! It's very bent, either because of the force exerted on it, causing it to shear the mounting bolt; or because it was getting trapped in the holes of the steering guard after the securing nut came off the chassis. I don't understand why that bracket would be there in the first place. It must have vastly increased the strain on the mounting. Mid Life; Live It!
Post #542007 21st Jun 2016 9:17am
It certainly does look like much more force has been excerted on the bracket.
Post #542037 21st Jun 2016 11:47am
The Hulk
Job done!
I had to remove the steering guard, which was a pig of a job for access - the o/s rear bolt took 20 minutes alone and the o/s front was so tight that I sheared the bolt Shocked
Anyway, I fitted the damper as nature intended without that strange bracket, tightened everything up, and... what a difference! I'm not comparing to the OEM damper because I didn't have one but compared to the previous botched fitting it's like a new motor. Steering is relaxed and the previous wobble has disappeared. It's almost civilised Laughing
I suspect this is the reason for the strange bracket - fabricated to allow access to the PTO winch?
All done and now time for a glass of wine Cool
 Mid Life; Live It!
Post #542159 21st Jun 2016 7:29pm
300TDi CSW Phil
That looks much better. Did you replace the rubber bushes at the pin end. Just noticed they look a little perished in the earlier photo's. 1995 300 Tdi Epsom Green - It's a keeper.
M0XQS
Post #542188 21st Jun 2016 8:16pm
The Hulk
Nope! They did look a bit perished but once cleaned up they were fine. The damper is only a couple of years old so it should be good for a while yet Whistle Mid Life; Live It!
Post #542229 21st Jun 2016 9:40pm
Lotus_esprit_s1
The "strange bracket" is indeed to drop the steering damper to allow it to clear the drive to the hydraulic front mounted winch which was once fitted. I expect yours is an ex utilities defender modified by Special Vechiles.
Post #542264 22nd Jun 2016 6:51am
The Hulk
Yes, it's ex-utilities. That bracket clearly isn't up to the job. Either that or the mounting bolt has simply worked loose and it has become mangled over time before finally detaching. Mid Life; Live It!
Post #542279 22nd Jun 2016 7:36am
Lotus_esprit_s1
To be honest the bracket is up to the job it was intended for - securing a standard steering damper. Your return to centre damper is putting a lot more force on it that it wasn't intended to cope with - that coil Spring is constantly exerting pressure on the bracket by trying to centralise the steering.
My view on those dampers is that they are fitted to try and mask other issues such as slack swivels, worn joints, worn bushes, tracking out, or 2" lifts messing up the steering geometry.
Post #542392 22nd Jun 2016 12:51pm
The Hulk
Can't argue with you on that score. They seem to be more geared towards off-road stuff so I'd question the value of them for normal road use. It was on the truck when I bought it with no original as a spare so I'm just making the best of it by ensuring it's fitted correctly. Mid Life; Live It!
Post #542399 22nd Jun 2016 1:11pm
I Like Old Skool
United Kingdom 1994 Defender 110 300 Tdi ST Coniston Green
Take it off and throw it away. If your other steering components are up to scratch then the standard steering damper does nothing and you won't notice the difference of having it fitted or not. As has already been said, the damper is great for masking other faults. I once had a series land rover without a damper that would sometimes shake-its-head alarmingly at certain speeds if I hit a small pot hole or similar (search 'Death Wobble') I have often run my Defenders and Jeeps without steering dampers when the dampers have been damaged/failed.
Post #542664 23rd Jun 2016 8:43am
