Home > Technical > Fitting of a wing fuel tank and mud shields on a 110?
Cupboard
Has anyone got a wing fuel tank fitted that would mind hazarding an opinion on whether it would fit round the Gwyn Lewis mud flap/shield kit?
Or possibly would be able to take some pictures so I can have a guess!
If you have got a wing tank fitted I'd also be interested to know how you got on with fitting it and whether you'd do the same again.
Post #541868 20th Jun 2016 7:10pm
shaggydog
Doubt it would as the wing tank takes up the space which is being occupied by that bracket.
Having said that I don't have one fitted so cannot 100% confirm ether way.
Which is sort of helpful? Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197
Self confessed mileage hunter Very Happy
Post #541872 20th Jun 2016 7:32pm
leeds
It is a long time since fitted a wing tank. Best done on a four post with wheel off. Main tank needs dropping to fit the balance pipe. Best done with minimal fuel in tank as less to decant.
Very much doubt if you could also fit the mud shield. Also not really needed as the wing tank is a snug fit. Clean the wing area then waxoyl/treated it before fitting the tank. Then becomes slightly messy job if treatment not cured!
With a 33" diameter tyre (255/85/16) which is full of mud, max articulation upwards then the mud scrapes the wink tank, so not muchroom for extra mud shields.
HTH
Brendan
Post #541878 20th Jun 2016 7:48pm
Cupboard
Thumbs Up
Thanks.
If I do end up with a tank there it's going to look weirdly lopsided then Laughing
Post #541891 20th Jun 2016 8:00pm
jst
i have a wing tank from Brendan there. both wont go together but you could fit the top part of the mud shield in frnot of the tank to keep the muck off the top of the tank.
will take some pics tomorrow if i remember! Cheers
James
110 2012 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #541903 20th Jun 2016 8:22pm
