Home > Td5 > ABS/TC Lights |
So you don't even get it to light up on the self test sequence at ignition turn on? I'd be looking to see if the bulb is there and actually not blown.
To save yourself a lot of hassle would be to get it back on diagnostics and see exactly what it says |
19th Jun 2016 9:44pm |
miker Member Since: 13 Sep 2015 Location: Surrey Posts: 1763 |
Had that thought, It's all LED's on a PCB. Though now I've figured out the switching logic (negative switched, not positive!) I will be prodding it again.
The LED's themselves are fine, but I can't rule out a fault in the triggering circuit just yet. The plan is to get in on the PC again, just good to have some ideas! |
19th Jun 2016 9:47pm |
