Home > Maintenance & Modifications > Fridge location |
TC Member Since: 21 Nov 2010 Location: Gloucestershire Posts: 715 |
Think this maybe what you are after.....drop Matthew a PM (Sonic3d) |
20th Jan 2011 8:04pm |
ti-fat-man Member Since: 08 Feb 2009 Location: Bedford Posts: 517 |
i'll second a responce on this one please...
i'm still looking to mount an engel mt45 in that space to. sure a couple of guys here got a bracketry solution, would love a couple of pics |
20th Jan 2011 8:30pm |
20th Jan 2011 8:32pm |
yeah seen that...
might be out of my budget though, that sure looks expensive though, all that runner stuff might mean $$ i'm up for the 'less is more approach' and a static fixed platform for the fridge to sit on. i'm happy to 'slum it' and reach in for a cool beer... |
20th Jan 2011 8:38pm |
Be surprised if it was hugely expensive........HD draw runners and some suitable brackets where the seats were. Won't be as cheap though as taking the seat out and bolting it directly to the floor! |
20th Jan 2011 8:45pm |
deffo get that...
but it (an engel mt45 nose to tail) won't bolt directly to the floor , without the MPS 'chop shop' bracket. it's the lead on the false floor that i think we are seeking, i think. a shelf on the seat base would deffo make the fridge to high for the lid to open, and certainly to high for me to peek into... Last edited by ti-fat-man on 20th Jan 2011 9:42pm. Edited 2 times in total |
20th Jan 2011 9:02pm |
I am intrigued now.....let's see what else the thread turns up |
20th Jan 2011 9:06pm |
leeds Member Since: 28 Dec 2009 Location: West Yorkshire Posts: 8582 |
In our red 110 we have an engel mounted transversely on a level with the seat boxes. It sits above a 70 litre water tank on the Engel base plate. It is also ratchet strapped in as well. With the Engel fridge when opening it you have to be careful that the lid does not 'walk' off the hinges. Apparently there is a conversion kit available to stop that now.
Black 110 the 60% rear seat comes out. (Blooming heavy!) The ARB fridge sits longitudinally in the back on a wooden base and is accessed from the front seats. It is ratchet strapped in. Have removed various seat bolts and bolted down some lightweight lashing eyes. Personally we prefer the ARB fridge over the Engel fridge Brendan |
20th Jan 2011 9:34pm |
AndrewS Member Since: 10 Apr 2007 Location: Hereford Posts: 3708 |
Is the fridge mount going to be permanent?
Do you need the 40 split 2nd row seat? If not remove the seat make a platform for the fridge. Yellow is a platform, pink is the fridge blue is a hand cubby box under the fridge ideal for ropes straps etc Click image to enlarge 130's have feeling's as well you know |
20th Jan 2011 9:37pm |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8096 |
my engel 45 is mounted where you describe. i just removed the 40% seat, and then made a flat platform for it. it picks up on the rear seat bar thing and then has two feet at the front dropping into the footwell. held in place with a ratchet strap through the fridge handles to the passenger seat frame on the front and the load guard on the rear. Cheers
James 110 2012 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
20th Jan 2011 9:45pm |
Oh I know thats the wrong side of the vehicle, I could only find a pic of the drivers side. 130's have feeling's as well you know
20th Jan 2011 9:51pm |
cheers james, a pic of your bracketry set-up, then we're sorted ta
thanks al. |
20th Jan 2011 9:53pm |
TJ101 Member Since: 30 May 2007 Location: Taunton Somerset Posts: 3750 |
??? Mine is very similar to JST, or his to mine Seat out, then a ply floor cut to shape, on top, with supports underneath, into the foot well, then the 45 ratchet straped to the fog/load guard,,, no at such Off to find a picture, i think i have ??? California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1 Main Brian James Trailer Dealer for South West UK |
20th Jan 2011 10:04pm |
kzycnn Member Since: 24 Apr 2009 Location: Northumberland Posts: 277 |
At the moment I have the fridge lock base thingy for my engel 40 litre permanently fitted transversely under the 60% seat with the edge of the base directly behind where the seat base rear bracket would sit. This means I can just roll the seat forward and clip the ridge in to place or remove the seat all together (as it now can't be used and just takes up space!) It's a TD5 so the seat frame is a bit different.
I like the board idea on the 40% side, but the only one like that I have seen in practice means the passenger seat has to be moved forward leading to a (very) cramped seating position. If there is a way round this, I'd be very interested.... Have also considered the MPS cutting the floor option but understand the floor brackets are no longer available? I also like the fridge slide idea. Does the door stay have to be modified/removed to enable the fridge to come all the way out, or does it open wide enough any way? Tony |
21st Jan 2011 8:06am |
