![]() | Home > Puma (Tdci) > Central Locking fault on drivers door in cold weather ? |
Zinke Member Since: 27 Jan 2009 Location: Scunthorpe Posts: 670 ![]() ![]() ![]() |
Very common problem. Strip the door down a lube everything up, this normally stops the problem. There is also a problem of something in the door catching, cant remember what exactly as i havent had to do it myself but im sure somebody on here knows.
Pete. |
18stone Member Since: 16 Dec 2010 Location: Mid Essex Posts: 137 ![]() ![]() ![]() |
Oh no!! Please don't say this is still an ongoing problem in Pumas too!! I've just endured years of similar behaviour from my TD5 and I have got a new UXS on order- hoping to leave behind such issues. The colour has drained from my face....
kingofthesparks Member Since: 06 Jan 2011 Location: Very close to Watford gap services , northants Posts: 987 ![]() ![]() ![]() |
Its a Land Rover, so dont expect the problems to be ironed out for another 60 years or so
JamesRS4 Member Since: 20 Jan 2011 Location: Hampshire Posts: 37 ![]() ![]() ![]() |
![]() Cheers |
![]() All too true KotS. |
My last Puma was fine but I had the same thing on he same door on my new one before Xmas. Removed the door card, checked and lubricated everything, door card back on and it has been fine since. Steve.
Thanks Chaps ! It's nice to know it is a reasonably easy fix .
James |
Make sure the locking button is running smoothly and that the guide it runs in isn't bunged up with dust or badly adjusted, there are two securing screws but the holes are slotted which give you a bit of adjustment. Steve.
Arctic Member Since: 25 Aug 2010 Location: Europe Posts: 45 ![]() |
If you fit a Webasto heater (or similar) then you should avoid these issues. Very good for the engine too and pretty much essential up North here. No need to scrape any windows in the morning either!
cobs Member Since: 12 Jun 2008 Location: North Yorkshire Posts: 336 ![]() ![]() ![]() |
ACF-50
I used exactly that excuse to persuade my missus that a Webasto would be a good investment on our TD5. Alas, the door problem persisted but, you're right, great to drive a TD5 from first off running smoothly with a warm cabin too. ![]() |
wurzell Member Since: 29 Jan 2011 Location: oxfordshire Posts: 141 ![]() ![]() |
hi
As above spray lock with ACF-50 to stop it freezing up. Do a search on this forum for same problem |
hi all
