Home > Technical > Alarm "issue" |
Paul_1978 Member Since: 08 Nov 2009 Location: South Yorkshire Posts: 384 |
Does your horn work off the stalk?
My TD5 alarm work off the cars horn, went off on Monday night and scared the hell out of me. |
20th Jan 2011 1:07pm |
daviec1 Member Since: 30 Nov 2010 Location: Ayrshire Posts: 246 |
yep - horn works perfectly using the stalk 2001 TD5 110 DCPU in Bonatti Grey
20th Jan 2011 1:40pm |
Zinke Member Since: 27 Jan 2009 Location: Scunthorpe Posts: 670 |
The problem with this one is that the ECU for the TD5 needs the AS10 unit fitted to work. When you disarm the immobilizer it sends a signal to the ECU telling it to let the engine run, no signal and the engine wont run. You can have this programmed out but you need to be talking to somebody like Pete from BAS to get this sorted. Fitting a new AS10 unit may help but the problem may not be with the unit but there are 2 types of AS10 so make sure you get the right one if you try it. There is a alarm sounder as well as the horn on a TD5 but im not saying where on a open forum, you never know who is reading! Have you tried reading the settings for your alarm and seeing how its set? It may just want changing in the settings to get it working again. Pete. |
20th Jan 2011 3:45pm |
Thanks to Pete for his PMs.
I decided to spend this afternoon completely cleaning the under seat fuse box, and the in cabin one. Each fuse out, quick blast of compressed air, and then replace So I come to the under seat fusebox, where I have already checked every fuse, get to fuse number 6 (15AMP) for the alarm. Still intact - take it out, blast with air, fuse back in and finish up. Test alarm - WOW. Flashing hazards, horn sounding etc. etc. etc. Never knew Land Rover had such a modern feature as a alarm that actually made noise No idea how anything got away down into the connectors for this particular fuse, and did NOT short the fuse out. Do not know what it is, and now, don't really care. Just goes to prove - clean, clean & clean again. 2001 TD5 110 DCPU in Bonatti Grey |
20th Jan 2011 5:43pm |
Glad it was something simple! Nice to know that the immobiliser and CDL still work when the fuse for the alarm is blown (or bad contact in this case), im sure it will come up again sometime and we now know where to start looking.
Pete. |
20th Jan 2011 6:08pm |
