Home > For Sale & Wanted > [Wanted] TD5 air conditioning parts
jrule
United Kingdom 2000 Defender 90 Td5 CSW Oslo Blue
I want to retrofit airconditioning to my county station wagon. If any one can help or is looking to sell their parts I will buy…
Thanks[/code]
Post #541037 17th Jun 2016 11:40am
dantastic
I have most bits left over from my TD5. Everything in the photo. Including the extended nose cone which you'll need to fit the condenser.
You will need to do some wiring yourself unless your TD5 has the AC engine loom.
The other thing is the compressor has the wrong connectior for one of the hoses. The connector is 180 degrees around in the connector block. The part number is correct so I don't know why that is. That meant I actually cut the hose, turned it around so one of the hoses is bodged together with rubber hose and hose clips. Other than that I believe this is everything you will need. You can weld the hose if you can weld aluminium, otherwise you way need a new hose and a correct model connector block for the compressor. If it's of any interest to you I'm open to offers.
Post #541189 18th Jun 2016 6:59am
jrule
PM sent
Post #541195 18th Jun 2016 7:16am
mk1collector
Wish I'd asked now as I've been looking for ages Big Cry if anything goes wrong I'll have 2nd dibs at the right price Thumbs Up Ray
My build thread
Post #541225 18th Jun 2016 10:52am
jrule
Looking forward to having cold knees Thumbs Up
Post #541226 18th Jun 2016 10:58am
NickMc
I have the dash bottom (post 02), some hoses, grille and some other parts. If you're still looking.
Post #542738 23rd Jun 2016 1:37pm
jrule
We've agreed a deal but thanks for you message…@mk1collector may still be looking?
Post #542760 23rd Jun 2016 4:23pm
