Home > Td5 > TD5 Rocker Gasket - Any other jobs at the same time
Harry.O
United Kingdom 1989 Defender 90 300 Tdi ST Nato Green
I've got a seep of oil coming from the rocker cover, whilst I have the top off to change the seal is there anything else also worth doing to a TD5? I was thinking of the injector washers and O-rings which are fine at the moment but could be changed as a preventative measure. Perhaps injector harness O-rings also?
Thanks in advance,
Harry
Post #540799 16th Jun 2016 5:53pm
landroverdiver
I did the injector loom because I had to. May be worthwhile, and simple to do. I had oil in ECU red plug. Possibly a waste of money, maybe not?
Post #540803 16th Jun 2016 6:15pm
Screbble
Yep, +1 for the injector loom with the mk1collector sealing mod Thumbs Up
Post #540807 16th Jun 2016 6:31pm
mk1collector
Post #540816 16th Jun 2016 6:45pm
Harry.O
Thanks for all the quick responses gents Very Happy I've got a genuine injector loom so will throw that in at the same time. Any more info on Mk1collector's mod?
Do I bother with injector washers and O-rings or is that tempting fate?
Harry
Post #540829 16th Jun 2016 7:13pm
Fatboy Slim
Wales
I normally do injector seals at 60-70K as a preventative measure. For the sake of an hours work it's worth doing. I change the injector hold down bolts and rocker shaft bolts as well.
Post #540843 16th Jun 2016 7:27pm
Screbble
Ta da!
http://www.defender2.net/forum/topic37090....ector+loom
All you need to know about sealing said loom, courtesy of Ray Thumbs Up
I never considered the injector seals. Something for me to do over summer methinks. Thumbs Up
Post #540890 16th Jun 2016 8:45pm
4RF RDS
Canada 2000 Defender 110 Td5 XS CSW Epsom Green
The half round black rubber seal for the cam (located at the front of the engine). Often leaks with age. Change that out too. 2010 Range Rover MkIII Autobiography Super Charged (Idris)
2003 Range Rover Mk III (Desmond FitzWilliam)
2000 Defender 110 CSW TD5 (CTX)
1992 Range Rover Classic (Lizzy)
1972 Series III 300 Tdi (Stanwood)
1967 MGB GT
Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats.
H. L. Mencken (1880 - 1956)
Post #540933 16th Jun 2016 11:04pm
miker
The only td5 that doesn't leak oil is the one with no oil in it - Wise old Chinese proverb.
Post #540934 16th Jun 2016 11:11pm
NickMc
The cam cover /bung seal tend to be the real culprit for leaks.
Post #541678 19th Jun 2016 10:37pm
Harry.O
Thanks for the advice guys, most appreciated, will definitely seal the loom as per MK1collector's mod before fitting it.
Could anyone advise on an appropriate type of sealant to use? I was looking at Sikaflex 512 which is not conductive but there is no info as to whether it's oil resistant.
I was planning to use RTV for the 1/2 moon on the rocker gasket and the cam seal.
For reference part no's are below:
Rocker gasket - ERR7094
Injector loom - AMR6103
Injector washers - ERR6147
Injector o-rings - ERR7004
Front cam seal - LDI100030
Injector hold down bolts - MBD100050
Rocker shaft bolts - FS106307L
Thanks,
Harry
Post #542303 22nd Jun 2016 8:46am
