![]() | Home > Maintenance & Modifications > Changing headlights for use in Europe |
TwelveSticks Member Since: 19 Jan 2011 Location: Dublin Posts: 5 ![]() ![]() |
I'm a D3 owner, but am looking at buying a RHD Defender (either a TD5 or possibly a 300TDi) in either the UK or Ireland to take to keep in France. One of the things that needs to be done is to change the headlights so they shine the other way. Can anyone shed any light on how easy this is to do? How much would this likely cost, and how easy is it to get the parts?
Thanks in advance... |
jomara Member Since: 26 Oct 2009 Location: Lanarkshire Posts: 1790 ![]() ![]() ![]() |
If you look at some of the parts specilists they have LHD headlights at around £15 per unit or you could invest £1.50 in a roll of black tape. 2014 110 2.2TDCi XS Station wagon
1971 Bowler Tomcat 88 4.2 V8 Auto 2022 110 D250 XS Edition - Gone 2024 110 D250 X-Dynamic HSE |
Defender lights Shine not words I understand
Thanks guys. Sticky tape not an option as the Defender will have to pass the French equivalent of the MOT and has to have proper 'left hand' lights. £15 a unit is my kind of price though
![]() Though, from ken's comment, maybe I should take the chance to upgrade the lights too while I'm in there. Are there any options out there for fitting better 'standard' headlights (albeit left hand ones), as opposed to fitting extra spots etc.? |
These are fab
![]() ![]() Click image to enlarge and as an oveseas owner has some I'd guess LHD is an option HOWEVER not £15.00 a lamp |
you could also look here ...
http://www.pro4x4-74.com/occasions.php http://www.centres4x4.com/01-Reseau/index.asp cheers |
noworries4x4 Member Since: 24 Dec 2010 Location: Newton Abbot Devon Posts: 1195 ![]() ![]() |
I run the Cibie Valeo 7" standard swap for the originals you can get them in left and right hand drive beam pattern they are a great cheap upgrade, i went silly on the bulbs PIAA chrome but they are superb.
I dont do the tape thing when going abroad 15mins and the headlight units are swapped easy if you have a spare set of rings 7 scrwes a side job done. Got mine from Europa web site If everything is under control you are not going fast enough. Every Day 16 MY Discovery 4 Commercial Workshop and Escort Vehicle Weekends 07MY L322 TDV8 Vogue SE Series 1 80" 3ltr 6cyl with overdrive No Worries 4X4 |
Excellent - thanks noworries4x4
Glynparry25 Member Since: 16 Feb 2009 Location: Miserable Midlands Posts: 3015 ![]() ![]() ![]() |
When do you need a set for... I have these: http://www.paddockspares.com/pp/DEFENDER/E...SA%29.html
In May/ June I head from here (Germany) to Cyprus so will be looking at getting rid of them about then if you are interested. Glyn ![]() |
Thanks Glyn. Haven't even got the Defender yet, but will bear that in mind when the time comes...
Nigel |
