Home > Td5 > Only First Thing - Chug, Chug them Oooomph
simon67
England 2004 Defender 90 Td5 HT Rutland Red
TD5 with Alive Stage 1
On starting up first thing either in the morning or afternoon, she will chug for about 100yds and then gets an enormous kick up the arse
Once she has got it out of her system, she is fine for the rest of the day and drives perfect afterwards
Any ideas?
Post #540013 14th Jun 2016 9:00am
jaygti
United Kingdom 2002 Defender 90 Td5 HT Epsom Green
My td5 has no remap, and does exactly the same.
I've had it over 4 years and it's always done it. I'd just assumed they all did it!
😕 2002 td5 90 county hardtop
Post #540018 14th Jun 2016 9:19am
huffhuff
United Kingdom 2001 Defender 90 Td5 HT Java Black
Mine always runs a bit lumpy first thing. More so in the cold. I always thought it was something to do with 5 cylinders but only 4 glow plugs.
Your waste gate isn't sticking is it?!? TD5 Defender 90
Discovery 3 HSE
Post #540021 14th Jun 2016 9:32am
Jimb1978
England 2002 Defender 110 Td5 Black LE Java Black
(Smug mode)
Mine doesn't do this and never has. Although it has been poorly lately. There are a few common issues that can cause symptoms like this and most are an easy/relatively cheap fix
See here
http://www.defender2.net/forum/topic47017.html 2002 110 td5
Post #540028 14th Jun 2016 11:02am
Fatboy Slim
Wales
Airflow meter knackered
Post #540031 14th Jun 2016 11:37am
Injector loom, maybe.
Post #540038 14th Jun 2016 11:59am
pj2106
United Kingdom 2008 Defender 110 Puma 2.4 USW Stornoway Grey
Mine does the same again with alive stage1 but did it before that
Done so far
Replaced injector loom
Maf unplugged
No oil in ecu
Had replacement turbo
Next steps are
change accelerator pedal
Injector seals
Replace loom again 2008 110 2.4 XS Utility (Hagrid)
2002 90 TD5 Hardtop (Sully) Sold
1998 300TDi D1 (Billy) Sold
Post #540131 14th Jun 2016 5:49pm
Fatboy Slim
Wales
Unplugging the airflow meter will give exactly that fault.
Post #540132 14th Jun 2016 5:59pm
pj2106
Done the same with and without mad plugged in just done it to eliminate route causes 2008 110 2.4 XS Utility (Hagrid)
Post #540195 14th Jun 2016 8:04pm
Fatboy Slim
Wales
If the airflow meter is dead it will do it. If you unplug it it will do it. Get it plugged into some diagnostics I'll bet it's sat there dead reading 4.40 Thumbs Up
Post #540197 14th Jun 2016 8:11pm
simon67
The only issue is that it had a full service and the alive tune at the same time
The diagnostics came back with faults and they were all cleared
So the MAF and injectors were all checked and sorted at the time
I'm just wondering if they all do that Sir
Post #540203 14th Jun 2016 8:27pm
Martin 01
Mine sometimes runs like that for a short while.
If I stop & turn off the engine then restart it, it seems to run better.
Why ?
I have asolutley no idea.
I also have an Alive remap, but been back & had it checked out & all showed well.
Beats me. Whistle
Post #540561 15th Jun 2016 8:14pm
Chris86
United Kingdom 2005 Defender 110 Td5 USW Chawton White
Chug Chug GO
Ours does the same, reverse it off the drive, drive to the end of the road, very flat, feels like its almost in a limited performance mode- get another 150m down the road and all is fine- usually on a cold damp day.
Its had all the of the suggested things replaced in the last couple of years, is no different. Of the three I used to use for work 2 of them did it- the other (newest one on a 56 plate) didnt?! Both of the the TD5 discos that another firm I used to work for did it too.
I have always thought its just a td5 quirk?!
Chris
Post #540577 15th Jun 2016 9:06pm
lightning
My 110 TD5 did this and it was hooked up to diagnostics which showed nothing.
I fitted a new MAF unit and the fault disappeared. The missus's 90 TD5 also had a similar fault when we bought it last year.
I called in to the Indy who sold it us, but l was in the 110.....the guy disappeared into the back and returned with a new MAF unit in a box and put it into my hand.
I fitted it into the 90 later that day. It cured the fault.
I think it's because when you start the engine, the ECU tries to take an input from the unit, and after a short time if the data is bad, defaults to preset settings.
Apparantly some cheap MAF units can be faulty from new! I fitted an OE to the 110, the one given to me by the lndy was a £30 one but it's been fine.
My advice is just change the MAF, if it doesn't cure the fault at least you'll know what it isn't.
Post #540962 17th Jun 2016 6:58am
shazzy90
maf but only use genuine
Post #541395 18th Jun 2016 10:59pm
