Home > Maintenance & Modifications > Interior Storage Pictures - Inspiration and Ideas |
KGH Member Since: 01 Feb 2015 Location: Florida Keys Posts: 61 |
http://shop.abenteuer4x4.com/shop/schlafausbau-multifunktion/
Very high quality. Removeable center/deck section. http://www.offgemöbelt.de/modulares-konzept-2/ Modular components one buys and assembles And this one allows 5 seats, completely removeable. I saw and had idea that I could build, but it is actuall very high quality, and if I attempted it would look like an amateur "wood butcher" had attacked my truck. http://www.kauai-camper.de/produkte/mobile...e-lrd-110/ 2013 110 - Keswick Green 1995 ExRAF 110 Utility 1986 127 HCPU 1985 110 PU 2012 Disco4 |
11th Jun 2016 6:09am |
Scotm Member Since: 28 Feb 2014 Location: Aberdeenshire Posts: 666 |
Terryt - You have given me a great idea with what to do with my spare dog guard.
I don't suppose you could give me some guidance on the shape of the brackets for your shelf? Maybe a close up photo? |
12th Jun 2016 6:47pm |
schweps Member Since: 21 Oct 2014 Location: Zonguldak Posts: 47 |
Hi Marc,
I'm flattered with your message. By the way, it is very nice job you have done. Cheers.
13th Jul 2016 1:23pm |
Terryt Member Since: 28 Jun 2012 Location: Lerryn. Cornwall. Posts: 750 |
Sorry for the slow reply leave it with me I'll sort some out for you it was easy really |
13th Jul 2016 2:11pm |
Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge Ok as promised ..wanted to make it easy for myself dog guard was left standard . Bracket made from a bit of steel with some trial and error it was bent to shape over the internal lip and outer cover these then take the original fitting with a lock nut . The rear section was a bit of U channel from homebase this is what the dog guard sits in and it's a good tight fit the U channel is secured via little u bolts from home base used to secure wire in fencing .hold loads ,no issue with noise or rattle (which was a surprise) and if needed can be removed in about ten mins .. Hope this helps |
13th Jul 2016 4:22pm |
Brewstop Member Since: 28 Oct 2012 Location: South Oxfordshire Posts: 313 |
Here is the continuing work on my 110.
Thanks for the inspiration, keep the pics coming!! The net came from Brad at RocknRoad http://rocknroad4x4.com/product-category/webbing-cargo-nets/ Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge Sandy |
31st Jul 2016 4:23pm |
Frontrunner cub box slide adapted with cargo track and Frontrunner fridge slide (the slide that's been owned by at least three forum members!!)
9th Aug 2016 7:52pm |
Hairysteve Member Since: 15 Jun 2015 Location: Surrey Posts: 692 |
Aha, so that fridge slider finally gets some use
Nice one Sandy. |
10th Aug 2016 5:03am |
TDCi Guy Member Since: 17 Aug 2014 Location: Yorkshire Posts: 286 |
Really like that roof shelf you've got Sandy. Is that homemade? I'm guessing the bits of angle underneath allow you to slide storage boxes onto them? Tom
@tditomprice 100ā€¯ Defender Hybrid 2010 Alaska White 90 HT |
10th Aug 2016 5:49pm |
Thank you, It was bought from McS on the forum, http://www.defender2.net/forum/topic25858.html the angle underneath is to fit a table, it works very nicely.
I've added some extra mesh to stop anything moving forward under breaking, had the shelf shot blasted then prepped it and gave it two coats of black vinyl. Click image to enlarge Click image to enlarge Sandy |
10th Aug 2016 6:38pm |
It's given me an idea to run maybe two lots of angle under a similar roof shelf and then slide storage boxes onto the angle. This would be better for my current situation as our two dogs come everywhere with us, so the only useable storage I have at the moment is a barebox style box I made for on top of the wheel arch and bungee nets on the mud side panels.
I'd need to find some boxes with a lid lip capable of taking the weight of the contents inside it or maybe bolt something onto wolf boxes to allow them to be hung from near the top. Food for thought anyway. Thanks. Tom @tditomprice 100ā€¯ Defender Hybrid 2010 Alaska White 90 HT |
10th Aug 2016 6:59pm |
GREENI Member Since: 22 Aug 2010 Location: staffs Posts: 10381 |
Brewstop, great job
10th Aug 2016 9:12pm |
couplands Member Since: 31 Aug 2011 Location: Peak District & Cornwall Posts: 1826 |
Where did you get the extra mesh from..? Cheers Simon |
11th Aug 2016 8:19am |
Mash Member Since: 09 Feb 2015 Location: Guernsey Posts: 1674 |
Finally I took a pic of my set up, army issue Tommy bin:
Click image to enlarge Click image to enlarge Held in place with two straps from the box handle to the seatbelt mounting brackets. 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html 90 V8 - Maggie http://www.defender2.net/forum/topic42564.html 110 TD5 - Buggsy http://www.defender2.net/forum/topic59029.html 52HG25 lightweight https://www.defender2.net/forum/topic72342.html D3 Hse - Fiona Capri 2l S - Anna Think I might have a problem............ |
14th Aug 2016 2:06pm |
