Home > Puma (Tdci) > Just to be aware: LTB00177
Page 2 of 2 <12
Eduardo
Better to be without it, but still quite bad Sad
Is not a good thing have a failed part specially in the brake system
In my case when the pump failed dead quite fast (one day or less)
They give you an alternative if the pump dead tomorrow or in one week more?
Cheers Eduardo
Post #5280 5th Dec 2008 12:27am
totoD110
Re: Just to be aware: LTB00177
Hi guys Im a new owner of 08 Defender 110... thank you for this kind of post... my dealer ordered the parts for this Service Bulletin... again thank you! Bow down
Eduardo wrote:
Mine was already had this problem 4 month ago....
Technical Service Bulletin
No.LTB00177
09 October 2008
Subject/Concern: Brake Vacuum Pump Seal Oil Leak
Models:
Defender (LD) 2.4L Diesel Only
2.4L Diesel Only VIN-range: 7A732615 Onwards
Markets: All
Section: 206-07
Summary:
Oil leaking from the brake vacuum pump front oil seal.
Cause: Dirt ingress into the pump pulley seal resulting in damage to the lip and subsequent oil leakage (the new brake vacuum pump has a secondary dirt lip seal). Suggested Customer Concern Code - R31.
Action: Should a customer express concern, install a new brake vacuum pump (refer to Global Technical Reference GTR Workshop Manual, section 206-07 (70.15.19)).
Parts Required:
Description Part Number Quantity
Brake vacuum pump LR012183 1
Gasket LR004381 1
Labour Time:
Operation Description Operation No. Time
Install a new brake vacuum pump 70.15.19 0.7 hours
Repair/Claim Coding:
Causal Part: LR012183
ACES Condition Code: 42
Defect Code:
Post #5382 9th Dec 2008 9:15am
austen
Australia 2008 Defender 110 Puma 2.4 SW Stornoway Grey
Not quite with you fellows on this one. Where is the brake vacuum pump oil seal located? I have an oil leak on the driver's side dripping onto the roll-bar. Could this be it?
Thanks,
Austen.
Post #5389 9th Dec 2008 10:09am
Eduardo
Austen,
I don't have good photos, but this figures can help you to found it (comming from the workshop manual)
The second one is the piece
regards Eduardo
Post #5392 9th Dec 2008 1:15pm
austen
Thanks very much for the drawings Eduardo. I'll check it out.
Austen.
Post #5402 10th Dec 2008 5:02am
MK
Mine just died after being 9 days at the dealer for the 10kkm maintenance. Got it replaced.
Post #5410 10th Dec 2008 1:09pm
CapeLandy
South Africa
9 days!
That's quite some time for an oil change Whistle
I would be guessing they were changing quite a few other bits in that amount of time. Puma 110 - gone
Series III 1973 - going strong
Post #5421 11th Dec 2008 5:23am
Fontuin
2008 Defender 110 Puma 2.4 SW Zambezi Silver
Fontuin wrote:
Fatboy Slim wrote:
Transits have suffered from this problem long before Ford put the engine in the Defender and they still havn't sorted it.....
I was wondering about whether this was the case, the problem with the Transit was/is probably not as severe because it would not be used in hot dusty condtions to the same extent that Defenders are (we don't even have transits here in SA).
Fatboy Slim wrote:
......hope you chaps don't have probs Confused
Not a question of if, it is a question of when, the old pump will start leaking at some stage in the conditions I use my vehicle in.
It started leaking again at 33000km on the 29th December. I took it it in to the dealer late that afternoon who insisted I book it in immediately because it is a safety concern, this was not the case the first time, I got the vehicle back early on the 31st December with the new improved pump. Hopefully this one will last.
Post #6141 10th Jan 2009 6:48am
Page 2 of 2 <12
