![]() | Home > Puma (Tdci) > Is my EGR on the way out. Chukka chukka noise |
It's supposed to do that, unless it's making a really unpleasant noise!
It's just the valve cleaning itself after you turn the engine off. Not that it seems to make much difference to the longevity. |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17598 ![]() ![]() ![]() |
They're actually meant to be pretty silent in operation, but most aren't and the chukka chukka is quite normal. It may well go on for years without problems, but if it stops now (after having started) you'll need to do something about it.
Certainly nothing to worry about at the moment. |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20612 ![]() ![]() |
Try some Millers diesel additive, that'll help keep it clean too.
I also agree with above. |
Bluest Member Since: 23 Apr 2016 Location: Lancashire Posts: 4230 ![]() ![]() ![]() |
Cheers all. I have the Millers diesel additive as used it in my last car, so it'll continue in the defender.
rossy Member Since: 29 Nov 2010 Location: Co. Roscommon Posts: 1296 ![]() ![]() ![]() |
The time to worry is when it stops doing it !
I think I might look into blanking/deactivation.
