Loz2286 wrote:
FPR fuel leak woes continue...
Having replaced the regulator gizmo and gaskets last time, I bit the bullet and bought a complete FPR including housing and fitted it yesterday. Apart from chucking diesel all over the workshop yesterday as I didn't check the pipes were fitted properly, I thought I had it fixed. Had my MOT done today and it failed on....a bloody "fuel leak from the back of the engine." I did argue the toss but the guy showed me the little puddle on his MOT bay floor.
Rung up my local independent garage to book it in because I'm at a loss as to where the fuel is coming from. In the meantime any thoughts folks?
I have changed two or three now and the part that leaks is the fuel regulator its self i.e. seals inside at are held closed by the spring, leak out of the small telltale hole or pipe
2nd Jun 2016 4:00pm
Loz2286
Yep. Done that.
I'll let my chap, Graham Goodyer, look at it. If he can't sort it no one can.1999 Td5 110 CSW
1961 Series 2 88 LPG
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
