Home > Maintenance & Modifications > Terrafirma Rear Diff Guard Bolt size? |
Baytown Member Since: 30 Jan 2016 Location: Cairns Australia Posts: 83 |
Sorted.
M12 with a different pitch to my original bolts. |
2nd Jun 2016 12:12pm |
JOE_130 Member Since: 26 Nov 2014 Location: Chelmsford Posts: 104 |
Hi Ken,
Only just seen this thread. I think I have the same issue, I've left mine just with the bolts holding it round the diff housing for now. Do you know what the pitch is for the M12? I've been trying to find some hardware for ages! Thanks Joe |
2nd Jun 2016 4:01pm |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17337 |
They should be 3/8" BSF according to Microcat.
2nd Jun 2016 4:56pm |
G"Day Joe and Blackwolf.
Joe, we ended up fitting standard M12 x25mm hardened bolts. Initially when I posted the reply, we thought it had a different thread, but after chasing the female thread at the diff, turns out my holes were probably just holding dirt, hence my initial difficulty with the M12's. Not sure re the 3/8s. I thought all the bolts were metric? Anyway, Ihope the M12s work. I purchased 5, so if you get stuck, let me know and I'll send you two of mine. Best wishes fellers. Ken |
4th Jun 2016 12:04am |
Your front and rear axles (right up to the end of production) utilise metric, UNF and BS thread forms!
It could only happen on a Defender ! |
4th Jun 2016 7:01am |
