Home > Maintenance & Modifications > PC based GPS ideas |
bob neville Member Since: 30 Apr 2009 Location: Marbella Posts: 3248 |
John
I am running an old Compaq TC1000 tablet (works surplus so free !) with Memory Map and a USB GPS receiver. Works for me Bob |
18th Jan 2011 2:42pm |
I'm sure an iPad would do the job .. http://www.about-electronics.eu/2010/06/11...3-preview/
18th Jan 2011 2:52pm |
jlprojects Member Since: 10 Dec 2010 Location: now in Ireland Posts: 48 |
Neville,
Thanks for the input, I'll look at memory map. Most of my travelling is Poland, Romania and shortly Russia so I need to be careful about chosing the right software. John |
18th Jan 2011 2:53pm |
mick Member Since: 08 Feb 2010 Location: Yorkshire Posts: 2109 |
i use this set up
18th Jan 2011 4:43pm |
If I used that where I travel, they would shoot me for it, very nice though. I need to have something more compact. I did see one setup that had a touchscreen on the dash, I think I need something similar. John
18th Jan 2011 4:50pm |
Lorryman100 Member Since: 01 Oct 2010 Location: Here Posts: 2686 |
You should check out AndrewS install in his Landy
18th Jan 2011 4:53pm |
Andrew, Ken, RLD will have some good ideas or Bobbycrispbox on the D3 forum is into electronic gadgets
18th Jan 2011 5:15pm |
BigMike Member Since: 13 Jul 2010 Location: Lancashire Posts: 2253 |
assuming you have a GPS receiver, any netbook/laptop will do. Then you have options like memory map which is pretty good.
if its for driving on road rather than offroad you cant go wrong with a garmin 1690. Iin fact even offroad its pretty good combined with topo maps. Note though that topo maps are not as detailed as OS maps, but are useful to show terrain. |
18th Jan 2011 5:23pm |
discocuzzy Member Since: 16 Jul 2008 Location: surrey Posts: 1200 |
You will probably need Fugawi or Garmin Nroute for Russia and eastern Europe.
I have a Car PC with a Global sat waterproof USB gps with a programm called franson gate enabled so i can alt tab between programs (mem map, Nroute, garmin sat nav for PC) You will find most GPS recievers are manufacturer software specific so the above allows you to spoof the software into thinking you have the correct one. PC mounted in the bottom of a mobile storage systems cubby box attached to a 10" liliput touch screen on the dash. Also enables all your Itunes library and DVDs to be viewed, plus a rear view camera fitted if required. Neat job, touch screen easily removed and stored in the seat pockets when not in use...you can lose the rear view mirror as well You cannot teach stupid people to do clever things |
18th Jan 2011 5:44pm |
sounds like a very cool set up disco. is your rear camera via USB or something else? I'm a bit tired of not being able to see directly behind when I have full load
18th Jan 2011 5:50pm |
Yep just a reversing camera up on the rack with a direct feed into the touch screen, just have to play with the cable routes to get it to the dash...i just ran mine through a gromet above the rear door and then under all the carpets,under the cubby and up behind the dash You cannot teach stupid people to do clever things
18th Jan 2011 5:55pm |
ken Member Since: 18 Aug 2009 Location: Banging Birds with my bitches !! Posts: 4328 |
Dont start with the LapTop start with Mounting Options first
D3 Set up Last edited by ken on 18th Jan 2011 6:08pm. Edited 1 time in total |
18th Jan 2011 5:57pm |
^ good point, not much room in a defender...have seen the laptop mounted on the passenger side with a remote screen for the driver...also works well but is a bit to in view for my liking. You cannot teach stupid people to do clever things
18th Jan 2011 6:00pm |
How did you attach the screen to the dash? bolted or something else?
18th Jan 2011 6:40pm |
