![]() | Home > Maintenance & Modifications > Warranty Work @ Stourbridge Bodyshop |
Gurmot Member Since: 01 Apr 2016 Location: Somerset Posts: 36 ![]() ![]() ![]() |
Not used Stourbridge but I have recently had LR approved body warranty work to my 2010 90 XS. They replaced the windscreen brackets as the ally had corroded and lifted the paint, and there was a small amount of rust starting on the windscreen frame close to the brackets, this was also covered. They also replaced the entire front grille as the lower painted mesh section had corroded. Strangely, they refused to cover the side window catches which had corroded in exactly the same way as the windscreen brackets, and they wouldn't deal with the rear cross member which had turned brown due to the woefully inadequate paint.
I'm not complaining though, quite happy they covered what they did. |
jaydt Member Since: 31 Aug 2013 Location: west midlands Posts: 36 ![]() ![]() |
The Stratstone Stourbridge approved paint shop is the owned by Stratstone and not a third party paint shop.I had warranty work done two years ago and was pleased.( then again a friend works there so things were put right that I didnt spot). Windscreen out resealed properly, window surround repainted,new hinges and lower aircon grill repainted. Windscreen surround just started to bubnle again tho.
