Home > Td5 > Rear heated screen. Rubber or no rubber TD5 2001 |
Alex1976 Member Since: 23 Jan 2013 Location: Buckingham Posts: 596 |
I am pretty sure that for your year the rear door pre-dates the move to a rubber seal (unless of course its not an original door). Your door should have the glass held in place by sealant and aluminium angles.
I am not sure about the difference in thickness but I would have thought with the above mentioned fitting method there is enough tolerance to handle either thickness. |
31st May 2016 7:47am |
Dave-H Member Since: 08 Feb 2011 Location: Surrey Posts: 1507 |
Early TD5 had the 'old' style two piece door bonded together with a bonded glass.
The 'new' style one piece steel door with a proper rubber seal mounted glass was fitted from late 2002 onwards. Later one [with a seal] has the 5mm glass HTH Guns and Landrovers .... anything else is irrelevant. |
31st May 2016 8:01am |
Clive Member Since: 21 Mar 2014 Location: Littleborough Posts: 467 |
Also the older style rear door window has squared lower corners, the later (rubber set) ones have a rounded profile.
31st May 2016 8:09am |
MC84 Member Since: 22 May 2016 Location: Near Bristol Posts: 360 |
I'll take a proper look at what I've got. Thanks for the input,
Mike |
31st May 2016 7:10pm |
