Home > Maintenance & Modifications > Soundproofing DIY Question
Grenadier
Hello all DIYers.
Quick question on sound proofing a 110SW for those who have tackled it. Is it necessary to get new carpet (my SW already has OE carpet fitted) or is there enough 'play' in the carpet to re-lay the original? Looking to tackle the work myself, but want to know if I need to buy a new carpet set or if I can use what I already have? For info, Dynamat will be the brand of insulation used.
Top tips welcomed, ta Thumbs Up Monsieur Le Grenadier
2011 Puma 110DC - Corris Grey
Post #535786 30th May 2016 8:16am
Rickydodah
The only problem I had was around the front seat box. You can stretch the carpet as it's not exactly Wilton. I found the contact adhesive I used didn't adhere to the foil backing very well but this may just have been that particular brand. The original carpet was attached with double sided adhesive tape around the seat box, maybe I should have tried that. Thumbs Up I started with nothing and still have most of it left!
Post #535790 30th May 2016 8:30am
Grenadier
Merci bien. Thumbs Up
So no real need to blow £300 on new carpet. Or at least give it a go and see how it pans out? Monsieur Le Grenadier
Post #535792 30th May 2016 8:32am
Roy5695
Id see how your old carpet comes off first, while ive been laying cables for the sub some of the seat box carpet is stuck well and felt like it was going to rip if pulled too hard.
Post #535793 30th May 2016 8:46am
Grenadier
Good point, cheers Thumbs Up Monsieur Le Grenadier
Post #535795 30th May 2016 8:47am
Anderzander
On my 90 the carpet did tear - although that was 15 years old ...
I didn't go with the silver stuff on the box one the basis that the surfaces are relatively rigid and didn't seem to drum - so I tired just the closed cell foam. (I'd used both in the back).
I then fitted the LR heavy rubber seat box cover - which fitted over the foam quite nicely. Having had the back done for a while - it was noticeable how much of a difference the foam made.
Post #535816 30th May 2016 10:32am
nitram17
Re: Soundproofing DIY Question
Grenadier wrote:
Hello all DIYers.
I think i must be going deaf! is the noise from a puma defender that bad?Has anybody done any proper sound measurments? Is soundproofing parts of the defenfer not a recipe for hiding the damp and rust especially if its stuck down to say the footwells!can you buy stuff that is removable.
Post #535860 30th May 2016 1:28pm
Rickydodah
Avec plaisir. Bow down
That was my thoughts before buying a new carpet to see how easy the carpet was to remove, I'm not sure if the double sided tape is how the carpets were installed in the factory (never had a Defender with carpet before, how posh is that?) but it held the carpet in place remarkably well. Thumbs Up I started with nothing and still have most of it left!
Post #535926 30th May 2016 5:19pm
Grenadier
nitram17 wrote:
Grenadier wrote:
Hello all DIYers.
Agreed. However this is for a client who has just bought a chalet and wants the Defender for clients/guests (all part of the Alpine image, although in her defence, she loves Defenders anyway). She wants it to be quieter and more comfortable, plus for the cabin to warm a little easier when it's -20c. She will never, ever go off road, bar the gravel carpark at the ski lifts... Thumbs Up Monsieur Le Grenadier
Post #536038 31st May 2016 7:27am
steventheplumber
England 1987 Defender 90 200 Tdi HT Keswick Green
Which after market heater are you going to install? Whistle
Post #536066 31st May 2016 10:54am
Grenadier
Very true, but I'm not paying!! Thumbs Up
But she has considered a Webasto for the future.
Anyway, I think the nsulation will make some difference, if not a huge amount. Monsieur Le Grenadier
Post #536091 31st May 2016 12:57pm
Matt110
Agree with the contact adhesive comment. Screwfix spray adhesive didn't adhere very well to the silent coat foil top layer.
Post #536125 31st May 2016 2:27pm
