Home > Maintenance & Modifications > Rust |
Zagato Site Supporter Member Since: 08 Jan 2011 Location: Billingshurst West Sussex Posts: 5013 |
Depends if you are going to keep it along time and are worried about the appearance. You won't be able to stop the rot but a quick tart up job may last a bit or if you are going to keep it a long time, new doors and a respray etc but ouch! It will cost and where do you stop.
17th Jan 2011 7:33pm |
TC Member Since: 21 Nov 2010 Location: Gloucestershire Posts: 715 |
I suspected replacement might be the best option......another one for the list!
17th Jan 2011 7:35pm |
Hide it with chequer plate like everyone else
17th Jan 2011 7:49pm |
Laurie Member Since: 22 Feb 2008 Location: Sussex, England Posts: 2897 |
If it hasn't yet become a structural problem, why not just blast the inside of the frame (thro' the holes) with Waxoyl?
Should stop it getting any worse. |
17th Jan 2011 7:51pm |
Not structural as far as I can tell, it is high up on the slope of the shut, not pooling at the seat of the door, the location lines up right underneath poorly seated window seals......quite an odd spot when you think about it.... |
17th Jan 2011 8:05pm |
110SEB Member Since: 29 Jan 2009 Location: Essex, England Posts: 1444 |
TC, if your vehicle is under 6 years old it's still under the LR corrosion warranty. Get on the phone to the stealer and get stroppy. It'll be covered.
17th Jan 2011 11:28pm |
It's an 03 so no chance on that front.....given that the rust isn't visible on the outside I think I will have a go at restoration. If I replace the doors I will then have the headache of trying to colour match 8 year old paint! |
18th Jan 2011 7:54am |
