![]() | Home > Maintenance & Modifications > How to break the taper on the drag rod? |
Bluest Member Since: 23 Apr 2016 Location: Lancashire Posts: 4262 ![]() ![]() ![]() |
I have one of those splitting tools in the photo. They do work, but I find it usually damage the rubber dust boot in the process.
Alien Member Since: 18 Jan 2015 Location: Bacchus Marsh Posts: 230 ![]() ![]() |
2 hammer technique...
Don't hit the thread, ball joint or tie rod. Leave the nut on the thread but loose, I allow a 1/4" gap. Place 1 hamer against the housing next to the taper. Hit it firmly( or harder) with hammer 2 on the opposite side. I've found 90% of the time 1 big hammer does the job. This should pop the taper and the nut is there so it does fall out on you. Cheers Kyle. Cheers, Kyle. |
![]() Kyle. |
Nevillerover Member Since: 14 Feb 2015 Location: Suffolk Posts: 224 ![]() ![]() ![]() |
My dad showed me the two hammer way 50 years ago. It's the best, doesn't damage the rubbers.
discomog Member Since: 09 May 2015 Location: Notts/Lincs Border Posts: 2538 ![]() ![]() ![]() |
Two hammer method has always worked for me, indeed this was the method I was taught by Land Rover during my apprenticeship over half a century ago. Unlike some of the removal tools it doesn't damage the rubber boot (unless of course you are a rubbish shot with a hammer). As Kyle says make sure you leave the nut on just in case you are a bad shot and damage the thread. Defender 90XS SW
agentmulder Member Since: 16 Apr 2016 Location: Outer Space Posts: 1324 ![]() ![]() |
I've worked with takers before on mills, and tapping it on the side occurred to me already.
Maybe I need to give it a bit more juice, as no dice when I tried with a 3lb hammer, cup of tea and a bickie. The video has one hammer - hrrrrrm, i don't quite follow where the second hammer fits in. Reading Aliens advice I'm not sure what 'it' refers to ('hit it firmly'), if it's the opposite side of the hammer you're hitting then why? If it's the opposite side of the housing then what is the hammer on the opposite side doing? I bet as soon as I see it I'll be like ohhhh, OK - of course... Thanks for the input, I'm sure I'll get there. Solved the bowel problem, working on the consonants... |
Ahhhh, lots of Google hits now I'm using better search terms...
sharkey964 Member Since: 05 Oct 2014 Location: On a muddy track Posts: 583 ![]() ![]() ![]() |
One hammer is fine,just give it a good hard smack.
![]() Marc |
Pilgrimmick Member Since: 16 Nov 2015 Location: Highlands Posts: 582 ![]() ![]() |
The other hammer hits the opposite side at the same time, sending a double shock wave through the steel. Takes a bit of coordination to get it right, but very effective. 80" 1948 Lightweight V8 Bowler Tomcat 130 Station wagon 90 300tdi (Santana PS10 pick up) Range Rover L322 (Ful fat) |
davew Member Since: 02 Jan 2012 Location: North Yorkshire Posts: 888 ![]() ![]() ![]() |
If you look carefully at the steering arm you'll see a flat "lump" on the side of it next to the taper - that's there for you to hit it with a hammer. No need to use two hammers, a good solid "tap" with a hammer on that flat will break the taper's seat. http://www.yorkshireoffroadclub.net/
I've never found the need to swing the 2nd hammer.
It's only used to get some mass behind the joint when needed. Found this which shows it @5:55 and @7:45(a little more suborn)... ] Cheers, Kyle. Cheers, Kyle. |
Perfect, the man himself too.
OK, acts as an anvil - must be some pretty hi-frequency jerk/snap in action. Thanks for linking that. ![]() |
pannawonica Member Since: 21 Nov 2010 Location: Clackline Western Australia Posts: 568 ![]() ![]() |
FBH just the ticket!
