Home > Maintenance & Modifications > Internal mounting of hilift, spade and extinguisher
agentmulder
Kuwait
Gidday,
I've got to secure a spade, hilift (standard length) and fire extinguisher in my 110SW 7 seater with rear seats removed. I assume the back is the place...
I've seen a nice set up with a dog guard and some pipe forming a kind of internal roll cage aft of the second row seats - not specifically for safety mind - anyway, the pipes went down from the top of the dog guard and angled down towards the rear, right near the fuel filler area that cuts in in the case of the RHS.
The pipe was standard scaff, so clamps and so on were easy and available.
I like it a lot, really secure, and with the separation, no chance of stuff coming towards you, also made the rear sliding windows slightly more 'secure' ( Rolling Eyes ).... Buuuut sometimes I put my mid seats forward and use the full rear area, so this would be a compromise.
Looking for other inspiration.
I know it's external but I'm also keen on a rear ladder (STC50417) - anyone repurposing these for mounting purposes?
 Solved the bowel problem, working on the consonants...
Post #534946 26th May 2016 8:22pm
Cupboard
The ladder will fit a small spade but not a big one, at least not without it sticking out over the roof line.
I have one of these that fits, but my bigger spade doesn't: http://www.screwfix.com/p/roughneck-27-/53829
In reality, I just store it behind the front seats as I have a bulkhead. If I'm thinking I might need the big spade, then that fits in to the load bay nicely wedged between my storage boxes.
Hi-Lift: be aware they're heavy and can be dangerous in an accident. They also work better with a clean mechanism so inside is good. Have you looked under the second row seats? I'm sure I've seen one put there.
Fire extinguisher: I don't have the rear quarter windows, so that's where mine is mounted. In front of the seat boxes or on the back door handle are both options. You can get Quickfists to mount them, some come with mounting brackets, but I've had to modify the mounting bracket mine came with to reduce the squeaking noises.
Post #535075 27th May 2016 7:53am
leeds
Nakatanenga do a mounting bracket for a hi lift jack under the middle seats of a 110
Brendan
Post #535120 27th May 2016 11:23am
I carry a 48" hi-lift inside my DC, it fits neatly across the front of the second-row seat brackets (effectively just behind the heels of the second-row passengers if I had any). It is secured to the seat brackets, and it still allows the seats to tip if required.
It keeps the weight within the wheelbase and low down, keeps the jack out of sight and clean, and is a space which is otherwise largely wasted.
Wherever you choose to fit the extinguisher, I suggest that it is somewhere you can reach from the driving seat. You really don't want to be trapped in a burning vehicle with an extinguisher just out of reach; that could make for a bad day!
Post #535128 27th May 2016 12:06pm
yaho
Poland 2007 Defender 90 Puma 2.4 SW Keswick Green
I just wanted to ask the same question but for the 90. Any solutions when there is no second seat row? Janusz
www.yahodeville.com
Post #535187 27th May 2016 4:46pm
ChrisCM
United Kingdom 2010 Defender 110 Puma 2.4 SW Santorini Black
My Hi Lift, in a soft case, lives under the second row seats together with a breaker bar and tow rope. Whilst the high lift is not fixed down the hinges on the front of the seats and the locking bars on the rear ensure nothing moves. 2010 Defender 110 Station Wagon, Santorini Black.
Post #535191 27th May 2016 5:03pm
LinDens90XS
2003 Defender 90 Td5 XS CSW Bonatti Grey
I have fitted two Quick Fists to the near side footwel just high enough for the seat support to fit, this holds my Highlift quite safe when I am greenlaning. Hope this helps. Regards
Dennis.
Post #535308 27th May 2016 11:34pm
agentmulder
Kuwait
Good option, I like how it mounts to the seat bolts:
Post #535542 29th May 2016 3:25am
Sphere
United Kingdom 2015 Defender 110 Puma 2.2 USW Keswick Green
Like this a lot been looking for a good option for a while. How much are the mounting kit?
Post #536272 31st May 2016 8:33pm
agentmulder
Kuwait
On a mobile so it's a pain navigating a German website, but have a dig around here:
https://www.nakatanenga.de Solved the bowel problem, working on the consonants...
Post #536274 31st May 2016 8:39pm
