![]() | Home > Puma (Tdci) > Low range light |
mse Member Since: 06 Apr 2008 Location: UK Posts: 5087 ![]() ![]() ![]() |
This was asked some time ago and is something i would really like to active...is it on the early workshop manual? Mike
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8208 ![]() ![]() ![]() |
i couldnt find any ref to it in manuals etc, these or on line, did a quick search here and didnt find an answer either. Cheers
Well i suppose logically its either got to be:
A switch on the High Low selector or a sensor that detects the transfer box setting. Mike |
James/Mike if you do get it working lets us know. 2.4 90 XS
I will have a look around the box area - if i do find something ill have a go, failing that i wont...james... Mike
When you say early how early ![]() |
all the launch vehicles had them working and the first ones we had through work had them, so 1st 6mths would be my guess - whenever that was. Cheers
Verdone Member Since: 30 Apr 2008 Location: Gent Posts: 67 ![]() ![]() ![]() |
Received mine july 2007 and no low range light
More cut backs ! 2.4 90 XS
Mine was one of the first on the road but does not have the light?
one_iota Member Since: 06 May 2008 Location: Sydney Posts: 99 ![]() ![]() ![]() |
![]() ![]() Do we need another light? The Defender has a little stick and the D3 has none. so... I reckon I know when I am in low range without a light due to only getting to 2 km/h in first gear at 4000 rpm ![]() '08 Defender 110 ex '95 Disco 300 Tdi www.aulro.com |
dm_td5 Member Since: 20 Jul 2008 Location: Arnhem Land Posts: 609 ![]() ![]() ![]() |
Try it in really, really soft sand. I went to take off in low third and got low one ![]() ![]() Definitely don't need a light for low range. But I might need one for the gear selection ![]() 110 300Tdi ![]() LROCV ::: AULRO.com |
Just thinking about it............ I expect the all have them and they simply don't work
