Home > For Sale & Wanted > [For Sale] Pair Wipac LED front sidelights - as new
dunc
United Kingdom 2016 Defender 90 Puma 2.2 XS CSW Corris Grey
Bought new from MPS Trading:
http://www.ebay.co.uk/itm/LAND-ROVER-DEFEN...Sw3oBTyPQk
I have now changed my plans for the front of my Defender.
In original boxes with manufacture date of 27/2/16. Fitted for one week, obviously as new. Complete with new unused stainless screws should you need them
Genuine Wipac, E marked.
£22 including postage
Post #534462 25th May 2016 8:16am
dgravedigger
Malta 1988 Defender 110 Other SW Baltic Blue
link is not opening. Make sure you have the right link or post the item number please
Post #534492 25th May 2016 9:48am
dunc
Thanks dgravedigger
Ebay item # eBay Item No. 261407069987
Post #534494 25th May 2016 9:50am
hxk494
I'll take these please, assuming they are a straight swap onto a 300tdi. The eBay add says 2007 on but pretty sure the connectors are all the same from 300tdi onwards. Do you know more?
Thanks,
Martin 1996 300Tdi Defender 110
Post #534508 25th May 2016 11:07am
dunc
Hi Martin
If you are near your Defender it would take you 10 seconds to remove the two fixing screws and check. My Defender has a white plastic plug that the fitting connected to the light slides into. The two pieces are held together by a latch on the white plug that catches onto a lug on the black plug.
If you cannot check on your vehicle perhaps MPS would confirm for you?
BTW when you pull the two bits apart be sure to hang onto the cable from the wing - it has a habit of disappearing into the hole and can be tricky to find again!
Hope that helps?
Post #534512 25th May 2016 11:14am
hxk494
Not near just now but pretty sure that's the same, remember fishing the lost plug out with bent wire before! I had a look online and suggestion is connectors [/i]may need to be reversed but that's doable.
I'll take them please, could you pm payment info, assume PayPal is OK?
Post #534518 25th May 2016 11:23am
Daisy90
United Kingdom 2001 Defender 90 Td5 SW Alveston Red
In case the other offers fall through, I'll have um please Thumbs Up
If not I may order a pair anyhow, they look smart Very Happy
Post #534672 25th May 2016 8:12pm
