![]() | Home > Td5 > RPM @ 60mph with 7.50 x 16 tyres |
110ross Member Since: 30 Oct 2010 Location: South West Posts: 33 ![]() ![]() ![]() |
Hi Steve.
I've got 7.50 tyres and Discovery2 T-box gears and I have around 2200rpm at 60mph so it sounds like you have the 1.2 T-box rato. Ross. |
Steve B Member Since: 22 May 2009 Location: Warwickshire Posts: 587 ![]() ![]() ![]() |
Hi Ross,
Perfect thanks for that, Defenders with the standard transfer must really scream then! Steve |
T1G UP Member Since: 08 Dec 2009 Location: Bath Posts: 3101 ![]() ![]() ![]() |
they do! hence mines having a 1.2. |
Steve, are you running a standard engine/ECU map?
When I first fitted the 1.2 T-box everything was fine - a bit sluggish in 5th, but nothing serious - until I bought a caravan. It towed just about ok but long hills were a real pain. After a while I went for a re-map to help. Ross. |
