Home > Puma (Tdci) > External shock reservoir location |
jimbob7 Member Since: 06 Jul 2013 Location: uk Posts: 2055 |
Look like this?
Click image to enlarge If it's for the image in your post,can you not just use a mirror??Maybe highlight the most used settings,assuming you don't use every single setting.You could even scratch your own markings on the visible side of the reservoir,so you don't need a mirror? Pov.spec,ftw. 2006, 110,TD5. |
19th May 2016 8:34am |
A handy inspection mirror...
19th May 2016 8:37am |
tomdaprince Member Since: 23 Feb 2015 Location: IJmuiden Posts: 54 |
Hi Jim, thats exactly how I have been doing it so far, however when all is covered in mud its not ideal, this is also a pretty vulnerable locations, want the reservoirs and hoses out of harms way. Otherwise terrific shocks btw.
19th May 2016 8:40am |
