Home > Maintenance & Modifications > Removing (temp) TD5 air con / footwell foam insulation query |
nickhodgson Member Since: 08 Dec 2009 Location: Zambia Posts: 174 |
If there is gas in your aircon you need to have it removed then you can disconnect the pipes and remove the whole aircon unit. After disconnecting the wiring.
Depending on the model the sound insulation fitted to the footwells and bulkhead is pretty good. Also depends on what sort of condition yours is in. I have in the past fitted Tdci or TD5 insulations to other defenders (with a few small modifications) and have been happy with the result. 1995 300tdi Defender 90 P/UP 2011 Puma Defender 130 D/C 2000 300tdi Defender 110 P/UP 2015 Discovery 4 SDV6 HSE |
18th May 2016 6:38am |
Lancerdoc999 Member Since: 10 Apr 2016 Location: South Wales Posts: 205 |
thanks finally managed to remove in the end. Those footwell inserts do look good but seem to act as water sponges for the leaks! If I can get them all plugged will probably add dynamat to the panels, replace them and cover with carpet.
18th May 2016 9:40pm |
incase others wanting to remove the zircon part of the dash its done as so.
degas the system. Mine was totally empty! unscrew the 2 screws either end of the dash and the central large screw. This detaches the whole unit. unplug the multi connector on the back of the central fuse box. unplug the condensation pipe in the foot well. from the engine bay side unscrew the two screws that hold the pipes from the compressor to the round part that pokes thru the footwell vertical panel. This sits in a rubber ring. from in the footwell gradually wobbles the unit and pull until the connector pulls thru the rubber ring and the whole unit comes away. Bobs your uncle! Click image to enlarge Click image to enlarge Click image to enlarge |
18th May 2016 9:53pm |
thewrongspeed Member Since: 27 Nov 2023 Location: Highlands Posts: 22 |
Currently facing the same situation of wanting to remove the OEM soundproofing to take a look at (and treat) the bulkhead areas above the pedal boxes and the passenger footwell. I really don't want to have to be removing the aircon stuff every time I want to gain access to those area so I think I'm going to cut the soundproofing into three sections. It seems that cutting it either side of the tunnel should make access really easy in future. He says, hoping.
23rd Jul 2024 12:42pm |
