Home > Camping, Caravanning and Holidays > Caravan electrics???
Thor
United Kingdom 2002 Defender 110 Td5 CSW Bonatti Grey
Having recently bought the caravan and done a couple of local trips whilst getting to grips with it all I have now booked a week in Torquay in the summer and am keen on having the fridge plugged in keeping the beer and bacon chilled whilst on the move.
I don't have the second set of electrics fitted to the 110 yet, only the connection for general trailer towing. My caravan is an 2009 van so has the older 7 pin style connectors. I've been to my local Indy who have quoted £260 + vat + fitting for the extra connection and split charge. This is LR OEM stuff.
It's a fair bit higher than I expected to be honest. Is this what people are paying? Could anyone direct me towards another kit that they Recommend?
I'll be doing the standard Google work when I finish work, but a couple of recommendations wouldn't go a miss!!
Thanks in advance.
Ryan Strong people are harder to kill and generally more useful!
Post #532685 18th May 2016 4:40pm
Laurie
Buy a kit from your local caravan shop and fit it yourself.
http://www.ebay.co.uk/itm/RING-RCT360-12S-...xyJs5RZtSr
Post #532686 18th May 2016 4:45pm
davew
England 1990 Defender 90 V8 Petrol PU Auto Rioja Red
You should consider converting to 13 pin electrics on the 110. It's only 5 additional wires (including 2 earths) and is going to be a better bet long term. It'll also mean you're not adding another socket just replacing the existing one. The 13 pin sockets/plugs are far more secure and waterproof than the old 7 pin ones and far more reliable as a result.
Of the 13 pins, 7 are the same as your existing socket, you then need to add a permanent supply (connect to purple wire behind the cover/speaker at rear RHS), Reverse light (usually a spare connector behind the fog light on the RHS), 2 earths - best to run them to the battery or a suitable point on the body/chassis and then the only "difficult" one is the supply for the fridge which you would normally run from a voltage controlled relay in the battery box under the seat.
Including buying the 13 way wire, 13 way socket and the "split charge" relay you'r probably looking at around £30 in parts.
If you don't want to convert the caravan to 13 pin then get an adaptor, they're anywhere between £10 and £30 on eBay depending on the style you want - I like the "short" all in one units rather than the plug and fly lead style but they are more expensive.
Split charge relay for fridge supply...
http://www.vehicle-wiring-products.eu/prod...arge-relay
Socket...
http://www.vehicle-wiring-products.eu/prod...ing-socket
A couple of metres of this will give you nearly all the additional wire you need (13 core version)...
http://www.vehicle-wiring-products.eu/prod...iler-cable http://www.yorkshireoffroadclub.net/
Post #532689 18th May 2016 5:03pm
gilarion
I bought this Genuine Defender kit from eBay last year for £60.00 and paid an auto electrician to do the fitting, he charged me a £80.00. To be fair if you know what you are doing you could do the job yourself as everything you need is in the kit.
http://www.ebay.co.uk/itm/262423873639?clk...rmvSB=true For those who like Welsh Mountains and narrow boats have a look at my videos and photos at..
Post #532691 18th May 2016 5:06pm
You could also contact Dan @ Duckworth parts R.E, Genuine parts.
Not likely to be cheap in its self but you could fit yourself.
Not particularly difficukt abd diagram readily available.
However, likely to be a bit time consuming hence their charges. (They have something nuts like £100 per hour)
Post #532695 18th May 2016 5:21pm
Stacey007
Hello
Do you just want the fridge to work while driving? how long is your trip. one day?
With my last car I never go the double electrics just single, however a few days before any trip I always plug the van into the house, charge everything up and test it all.
Fridge on the electric setting, with some ice packs, then the morning you leave take the stuff out of your house fridge and put it in the caravan fridge. If your only having say one stop over on the way it will still be cold believe me. Once on site your back on power anyway.
Worked for us on many trips Smile
Post #532725 18th May 2016 7:57pm
RoddyK05
Scotland 2004 Defender 90 Td5 SW Yellow
I'm with Stacey007 on that one. We are fortunate enough to be able to keep the 'van in the vicinity of the house and have 220v available to it. We chill the fridge, charge the battery and test everything before the off. Your fridge will definitely still be cold when you arrive on site if you load it with grub from the house fridge.
Getting our new 'van on Saturday, so new heating controls etc to get used to before we head off sometime during the summer.
Post #532818 18th May 2016 10:47pm
timbar
United Kingdom 2009 Defender 110 Puma 2.4 XS CSW Stornoway Grey
Just considering doing the same thing and found what looks like the fitting manual for the LR towing kit posted here https://www.firstfour.co.uk/media/wysiwyg/pdf/LR005919.pdf, thought I'd post it in case it's interesting to anyone else.
EDIT: 13-pin manual ... 2009 110 XS Station Wagon
Post #629298 5th Jun 2017 9:48pm
bear100
Simples, charge the van battery before leaving! 2023 Defender L663 V8
2010 110 XS Utility 2.4TDCI
1993 110 csw 200 tdi (gone)
1994 90 HT 300 tdi (gone)
1994 discovery 300tdi (gone)
90 hybrid 3.5 v8 (gone)
Post #629306 5th Jun 2017 10:06pm
