Home > Maintenance & Modifications > Check Temp Reset? |
Motoberg Member Since: 01 Oct 2015 Location: Aberdeen Posts: 104 |
Don't know the specific meter but if the sensor is an RTD ( resistive ) then a high resistance connection somewhere would give it a positive offset
17th May 2016 2:22pm |
ChrisCM Member Since: 10 Jun 2013 Location: Cornwall uk Posts: 572 |
Thanks for the reply, the gauge is a Check Temp II, quite a few forum members have fitted them, problem is the sensors and cabling is in one harness so I don't think the external sensor can be swapped out, can't think of any reason why the resistance would have increased as there are no joints to go bad.
Chris 2010 Defender 110 Station Wagon, Santorini Black. |
19th May 2016 5:21pm |
