Home > Td5 > fault code 10.1 air conditioning fan drive open load (logged
Castillo
Finland
I have problem with my defender aircon. If blue switch is 0 and I switch on white, it starts a/c blowing cold air. Nanocom says that 10.1 air conditioning fan drive open load (Logged). What it mean, where is problem. Blue switch does not work, there is allways same set and compressor starts on if blue is 0 or 1,2,3 and I turn white on 1. If I drive aircon on it blows too cold and it goes "freeze". When I switch off white and I wait for 15 minutes so air con start cold blowing if I switch on ghe white.
My english is poor and I edited little my story. I hope that you understand what I mean. How I can repair my car. defender 110 td5 2006
Post #529690 7th May 2016 9:32am
MadTom
Czech Republic 1999 Defender 130 Td5 HCPU Baltic Blue
A/C Fan is electric fan behind the mask. It is powered from a relay and the relay is controlled by TD5 engine ECU. Your fault means the open circuit between TD5 ECU and coil od the relay. Check relay and connectors for damage/corrosion. "Drobek" = The Small One - Discovery 2, "Blufínek" = The Blue Thing - Defender 130, and for me at least Ford Mondeo Smile
Post #529732 7th May 2016 12:47pm
Castillo
Finland
Thanks. How many aircon's relays are td5 defender. There is some relays under passenger seat and the yellow one says "naps" when white switch turn "one". Blue switch do anythig under passenger seat's relay, nothing "naps" if I turn on blue switch. I opened this yellow relay "box" and inside was "som new" defender 110 td5 2006
Post #529740 7th May 2016 1:46pm
MadTom
Look for RAVE - technical documentation from LR - there are schematics and placement and pictures of all connectors. And lot of other usefull technical information. "Drobek" = The Small One - Discovery 2, "Blufínek" = The Blue Thing - Defender 130, and for me at least Ford Mondeo Smile
Post #529747 7th May 2016 2:45pm
Castillo
Finland
There are some yellow relays (Ford V23136-B1-X33) under passenger seat. Where I can buy this kind of relays. Land Rover yellow relays in many webshops are differend numbers (YWB10027, YWB10012, YWB000150). Are those allright. How I can buy correct yellow relays to my car Confused defender 110 td5 2006
Post #530045 9th May 2016 7:17am
MadTom
No need for YELLOW relay - it is standard car relay, nothing special. "Drobek" = The Small One - Discovery 2, "Blufínek" = The Blue Thing - Defender 130, and for me at least Ford Mondeo Smile
Post #530057 9th May 2016 9:03am
Castillo
Finland
Now I have replaced new air con relays and fuses, but nothing help. What I will do after this. defender 110 td5 2006
Post #530698 11th May 2016 5:02pm
dorsetsmith
information for your Air con diagnostic good luck
Post #530743 11th May 2016 7:48pm
Castillo
Finland
Thank you very much Smile. I hope these pictures helps me to understand A/C system. I have never been anything problems with any car's air conditioning, I have visited in A/C service every other year with my cars (Mercedes, VW and Defender too). Smile defender 110 td5 2006
Post #530870 12th May 2016 6:27am
