Home > Maintenance & Modifications > Air con grille mount fitting advice
HossBog
I'm fitting an air con grille mount to my non air con TD5 - because I like the look - and I seem to need a lower fixing to link the air con grille and the inner wing - any air con owners with a pic of the part or any advice on the part?
Hopefully the pic shows what I'm missing!
There's also a hole in the side of the air-com grille mount that is parrellel, so it looks like there's a metal fitting to link the two....
Thx
Jon 2002MY Defender 90 H/T
Post #529770 7th May 2016 5:34pm
JWL
The piece that's missing is only a bit of strap with a self tapper through the air con nose and another at the back into the wing. Just cut a couple of lengths out of some tin and the jobs a good-un Thumbs Up
Post #529810 7th May 2016 7:45pm
HossBog
Thx a lot, I'll get the tin snips out tomorrow. Is the self tapper in the side of the grille mount panel just a standard philips? 2002MY Defender 90 H/T
Post #529831 7th May 2016 8:45pm
JWL
Yes it is on mine, a black one with a flared out head, like as if it's got its own washer moulded on like a trim fixing screw.
Post #529846 7th May 2016 9:42pm
HossBog
If anyone has got a pic of the fitting it would be massivley appreciated - I'm near a stealer tomorrow and it's always better to have a view of what you're describing to them... 2002MY Defender 90 H/T
Post #530330 10th May 2016 6:56am
nickhodgson
Try MTC6332, AK612011L and AB614065L. You will also need a flat washer. 1995 300tdi Defender 90 P/UP
2011 Puma Defender 130 D/C
2000 300tdi Defender 110 P/UP
2015 Discovery 4 SDV6 HSE
Post #530978 12th May 2016 12:00pm
