![]() | Home > Puma (Tdci) > Jerkiness From Engine |
110SEB Member Since: 29 Jan 2009 Location: Essex, England Posts: 1444 ![]() ![]() ![]() |
DMAKX, I have an 07MY and had plenty f jiggles but not this. It might be a trait of more recent machines and I'm sure there'll be plenty of suggestions on the way. My only advice is not to hesitate taking FULL advantage if the warranty. Some manufacturers choose to do R&D before they put to market. LR let us do it for them.
It'll be a simple issue and you'll be smiling again soon. |
dm_td5 Member Since: 20 Jul 2008 Location: Arnhem Land Posts: 609 ![]() ![]() ![]() |
PDH Member Since: 03 Dec 2009 Location: Shropshire Posts: 179 ![]() ![]() ![]() |
Mines been doing the exact same thing for the past week, getting progressively worse until on Sunday the Engine light came on. It was booked in the dealers anyway for some other warranty work so they're busy looking at it now, thinking EGR too although it was also showing an error code for the engine module. Will wait And see what they come up with Puma 2.2 90 Stationwagon |
DMAKX Member Since: 18 Nov 2010 Location: In The Middle Posts: 47 ![]() ![]() ![]() |
Thanks for the replies. My thoughts were the EGR too.
Its booked in for Monday so I'll see what they suggest. PDH, it would be good to hear what your dealer says is the problem. DMAKX |
Well just picked mine back up and apparently they just updated the ECU software, mechanic wasnt around to speak with to get more details but the drive home seems to confirm that its fixed!
will see over the next day or so. Puma 2.2 90 Stationwagon |
Alexke Member Since: 03 Jan 2011 Location: Antwerp Posts: 113 ![]() ![]() |
Injectors with mine ! i had all replaced under warranty!
it will get whorse does it shake when its running on idle?? Discovery 4 SDV6 Landmark F31 320dA Msport xDrive LR Defender 90SW TD4 Stornoway grey 320d E46 E70 X5 3.0d Sold! FFRR TD6 - Sold |
