Home > Puma (Tdci) > Dash Clock - Problem
Gonarezhou
South Africa 2015 Defender 110 Puma 2.2 SW Alaska White
Having observed the clock in my MY 2014 regularly lose about 5 min each day. I took it in for an under warranty repair. Turns out there is a JLR bullitin regarding clock failure and it is a fault with the clock not just your mind (although for some that may be a factor too)! Just some info for anyone with a similar problem - it is replaceable under warranty.
Post #528947 4th May 2016 12:12am
agentmulder
Kuwait
Replaced the bulb in mine and now it's slow...
Out of warranty - new clock is £50.
Weee bit boring, would rather have one on-time that I cant read at night, compared to one that is wrong. Solved the bowel problem, working on the consonants...
Post #528952 4th May 2016 4:52am
Roy5695
have you made sure that while you have had it out the clear face hasnt become dis lodged and is pressing on the fingers slightly?
when i painted the surround it took me a few attempts to get the clear face to sit properly Thumbs Up
Post #529083 4th May 2016 4:32pm
LoveTheMud
United Kingdom 2014 Defender 90 Puma 2.2 XS CSW Santorini Black
If you are gaining minutes, then I have no explanation.... but if you are losing minutes, then it may be a result of going too fast relative to stationary clocks... Rolling with laughter
Post #529098 4th May 2016 5:12pm
strang
United Kingdom 2009 Defender 90 Puma 2.4 XS CSW Galway Green
Funny you should mention problems with clocks. I am still having problems with Land Rover customer services. The clock in my 90 did not change to British Summer time again this year - who do I complain to? Very Happy Euro-Leafing to infinity and beyond.....
Post #529115 4th May 2016 6:57pm
Cupboard
Weirdly, mine adjusted itself forward an hour today!?
Post #529138 4th May 2016 8:27pm
Panda
England 2015 Defender 110 Puma 2.2 XS CSW Fuji White
A Timely Comment, I will watch this thread Rolling with laughter Monty-2015 2.2 110 XS Puma Station Wagon
Yoda Disco 3-Sold
Larry Disco 1-Sold
Muddly XS 90 TDCI-Sold
Pearl Disco 2-Sold
Larry Disco 1-didn't want too but sold
Post #529141 4th May 2016 8:32pm
agentmulder
Kuwait
Looking at it for a full 24hrs* I noted that it would occasionally make an attempt to move a minute but kinda hiccuped/farted at the same time and got nowhere. Sometimes taking 4 attempts at these 'boss' times.
Running it round and round using the + button didn't blow out the cobwebs.
Doesn't look like the hands are touching the cover but cant rule it out. I'll pull it out and run it on 12V inside the house and see what happens...
If it's still farty, I dunno, contact cleaner or WD40 in the mech?
*looking at it at the lights... Solved the bowel problem, working on the consonants...
Post #529151 4th May 2016 8:56pm
Gonarezhou
It was replaced ... no questions from the dealership on space time or Einstiens theory of relativity! Quite a relief actually...I was ready for a long debate with JLR that a Defender moving faster does not equate to time slowing down....my dear old beast does not even get close to the speed of light Wink Wink
Post #529640 6th May 2016 10:57pm
rossy
That'll teach you not to drive too close to a gravitational singularity again Thumbs Up
Post #529854 7th May 2016 11:01pm
tuesdayfox
2013 Defender 110 Puma 2.2 SW Zambezi Silver
my clock is never accurate.....I am planning to remove it and put a boost gauge there.
Post #529875 8th May 2016 2:19am
Shax
England 2010 Defender 90 Puma 2.4 XS CSW Stornoway Grey
I'm thinking of replacing mine with a digital display and a 3D printed surround / bezel...
I really don't like "tick tock" clocks.. ... ,-------,
.. I [__][_]|__
.. I __ |"_|"__|
.. "(o)====(o)"
^^_-^-_^-^_^^^^^--^^^^
PAUL
G7ALW 14.200 USB
26FB458 / 27.275 SSB
Post #530416 10th May 2016 7:21pm
agentmulder
Kuwait
Took it out and connected it to a bench DC supply for a day without the plastic cover. Didn't lose a beat over 2 days...
So it turns out I installed the clear plastic and the seal in the wrong order. I shouldn't have even taken it off in the first place, but I assumed it'd need taking apart to get a new bulb in there...
So the clear plastic has a rebate in it that looks like it's made for the seal, but nooooo, other way round chap!
With the wrong assembly order the plastic juuuust touches the hands which gives juuust enough friction to lose me a minute every 50min on average. Solved the bowel problem, working on the consonants...
Post #531170 13th May 2016 6:14am
