Home > Puma (Tdci) > Waggle at low speed |
bm52 Member Since: 04 Apr 2010 Location: Kent Posts: 2189 |
crikey - i'd check steering damper and all related steering rods and links first off.
also loose wheel or knackered bearing |
4th May 2016 10:40pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20121 |
Ball joint most likely.
4th May 2016 10:43pm |
zone30 Member Since: 07 Sep 2012 Location: Gent Posts: 669 |
Thx!
5th May 2016 8:05am |
5th May 2016 8:34am |
nickhodgson Member Since: 08 Dec 2009 Location: Zambia Posts: 174 |
Waggles? Related to steering wheel or whole car shaking? Does it happen when you accelerate of slow down or when you hit a bump? 1995 300tdi Defender 90 P/UP
2011 Puma Defender 130 D/C 2000 300tdi Defender 110 P/UP 2015 Discovery 4 SDV6 HSE |
6th May 2016 10:25am |
Ah sorry! Update: apparently I lost some wheel bolts which caused the issue. Scary moment bu thank god I saw it in time!
7th May 2016 8:18pm |
^^ You lost several wheel bolts? Any idea why, not torqued up to the required 133 Nm (alloy) or 170 Nm (steel) maybe?
Eric You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
8th May 2016 4:09am |
No idea. I always tork up. Keeping a close eye on it now.
8th May 2016 10:29am |
Caterham Member Since: 06 Nov 2008 Location: Birmingham Posts: 6276 |
Someone tried to run off with the wheels?
8th May 2016 11:30am |
Maybe. Who knows...
10th May 2016 6:00pm |
