![]() | Home > Puma (Tdci) > Rear seat conversion |
jrule Member Since: 10 Aug 2015 Location: Hertfordshire Posts: 302 ![]() ![]() ![]() |
Looks great, do you have to support the tub in anyway when you cut out the arches like that?
Fish13 Member Since: 17 May 2015 Location: Aberdeenshire Posts: 71 ![]() ![]() ![]() |
Thanks!
Yes, there's brackets that bolt into the rear crossmember and run under the arches. The seat belt bolt and a pivot bolt to stop the seat belt getting twisted bolt into them. |
barbel jim Member Since: 12 Dec 2012 Location: Northants Posts: 1438 ![]() ![]() ![]() |
Doing that to my TD5 soon where did you get the carpet from ?
Hi,
I got it from LRi solutions. I bought the 90 hardtop version as I had the fear that if I bought the actual county version (with the step down arches pre-shaped) it might not fit. I figured I can always trim excess, but can't do much if there's not enough to begin with. It is really good quality and surprisingly easy to cut/trim etc. Cheers, Fish. |
