Home > Technical > Slight 'ping' or 'clunk' from rear
Stacey007
Hello
2 noises I've heard more recently...
1) Noticed a few times now when setting off slowly, moving in a carpark etc I hear I slight 'ping' or 'clunk' coming from the back when letting clutch out.
Almost like the handbrake has 'pinged' free (but I've not out that on)
2) When the car is under load, slight acceleration say up a hill in a high gear, almost like a heat shield vibrating on the exhaust?
Vary rarely does it and hard ti replicate but a little odd...
Any idea what it could be had a quick look at exhaust bracket etc all looks ok, are they linked or separate,
Post #528855 3rd May 2016 8:01pm
Check the rear damper bushes especially the lower ones.
Pings sound like a stone or similar pinging the stone guards on the brakes.
Post #528877 3rd May 2016 9:18pm
Roy5695
akso check the ball joint in the fulcrum bracket, known to wear and will clonk when setting off...
Post #528886 3rd May 2016 9:28pm
Stacey007
Thanks
Are either of the above pricey?
Will it get worse / louder?
Post #528892 3rd May 2016 9:36pm
Bushes are cheaper than the above, either could be culprit.
Post #528898 3rd May 2016 9:45pm
Nevillerover
United Kingdom 2007 Defender 110 Puma 2.4 XS CSW Sumatra Black
One of my rear springs just moves a little on the mount and makes a noise sometimes when moving off. A sort of Spring twang noise. Could you have the same? Discos used to have a rubber comfort bush on top of the Spring. I've thought of fitting them.
Post #528910 3rd May 2016 10:01pm
Screbble
The ball joint isn't too expensive, but it's a pain to replace and 'press' in to the bracket, so I'd spend a few more quid and get one already inserted into the bracket - that is of course if it's the issue!
As Steve says, check out the damper bushes too. Quick and easy.
If it's a definite 'clunk' then my money's on the ball joint.
If you're intending to keep the truck, then I'd invest in this:
http://www.gwynlewis4x4.co.uk/product/a-fr...n-housing/
Easy to fit (and GL supplies a kit with the bolts and nylocs so you don't have to faff about!).
Post #528912 3rd May 2016 10:03pm
Nevilerover - You are quite right, on my old rear springs did have a slight knock near the top as the coils touched.
On the rear springs I fitted new last week they have upper coil wrap around isolators (prevents the above issues) I also fitted top of Spring isolators and lower Spring isolators.
There is a minor lift and ride quality is superb, I was pleased and very surprised but Genuine I went for are not cheap. Talking £90 for isolators only.
Scrabble - That looks good, I was surprised by the price I was expecting £150 plus at least.
How would you go about checking for play in it? Never took much time to check mine.
As far as I'm concerned I have no issue but one to bear in mind.
Post #528916 3rd May 2016 10:11pm
Happyoldgit
Potentially the A frame ball joint as has been said but other possibles are diff, pinion flange, prop uj's, drive flanges, main to transfer box intermediate shaft ...and a few others Wink Steve.
http://forums.lr4x4.com
Post #528921 3rd May 2016 10:19pm
Stacey007
Thanks all.
Looking under the car what am I looking for and where about....
Given I'm new ish to these thanks
Post #528950 4th May 2016 12:42am
Happyoldgit
Looking is ok but apart from getting down under and dirty and actually feeling for play in some of the areas with your hands your best bet is to get someone to gently drive the vehicle back and forth a short distance to try and replicate the sound while you try and pinpoint the area by walking beside the vehicle and listening from outside. Carrying this out on soft ground is sometimes more effective than on a hard surface. Steve.
Post #528994 4th May 2016 10:14am
keith
Well that pretty much covers everything then Rolling with laughter May as well buy another motor or do a full rebuild .
I've had the same wee clunk for 3yrs , checked every moving part and still there . HO-HUM
Post #529068 4th May 2016 3:38pm
Stacey007
^ Thanks
I will pop my head under and wiggle a few things... Smile
Will make a note if it gets worse...
Its due for a service before August so will ask the garage to biff a few things with a heavy mallet and see what rattles....
Post #529069 4th May 2016 3:46pm
keith
^ off topic
How's that trailer coming on ?
Post #529075 4th May 2016 3:57pm
Stacey007
Keith slow progress always lots on with the kids and a petting farm...
http://www.defender2.net/forum/topic43181.html
But progress....
I'm thinking of spraying it myself.... aaarrgghhhh
Post #529087 4th May 2016 4:44pm
