Home > Maintenance & Modifications > Rear ladder and Numberplate
shaggydog
Hi Guys,
I want to fit my rear access ladder permanently as I don't like the idea of having to unbolt and re-bolt it every time I want to use the roof rack.
Problem is, when fitted on the passenger side it partially blocks the number plate which is not so good.
I can fit it on the other side but this will require a modification to the mounting slots in the ladder.
What do we think?
Passengers side Blocking number plate
Drivers side not blocking the number plate Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197
Self confessed mileage hunter Very Happy
Post #528097 30th Apr 2016 3:22pm
Scotm
Scotland 2012 Defender 110 Puma 2.2 SW Orkney Grey
I have had a similar ladder fitted over the number plate for the past 16 years and not failed an MOT.
I also got a speeding ticket from a fixed camera with it fitted so I don't thing you need to worry about it over the number plate.!
Post #528115 30th Apr 2016 4:25pm
Rosco
United Kingdom 2015 Defender 110 Puma 2.2 XS CSW Montalcino Red
Can't say I've ever heard of anyone having issues with the authorities and the ladder obscuring the number plate, but you obviously have a doubt otherwise you'd just fit it to the other side.
All depends how big a modification is needed to the ladder to get it fit 2007 - Stornoway Grey 90 XS SW - Gone
2002 - Black Discovery II - Gone
2014 - Montalcino Red 110 XS SW
Post #528116 30th Apr 2016 4:27pm
JOW240725
If you were worried you could weld in a loop around the number plate?
Post #528137 30th Apr 2016 5:23pm
miker
Hannibal roof rack, full height ladder, been there for 16 years and 180000 miles!
Post #528206 30th Apr 2016 11:45pm
Or just move the number plate to the other side?
Post #528222 1st May 2016 5:49am
shaggydog
Thanks guys for all the replies. Bow down
As it will only need a slot cutting in the mounting bracket I think I will just put it on the drivers side and then forget about it. Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197
Post #528300 1st May 2016 12:12pm
DuncanS
United Kingdom 2008 Defender 110 Puma 2.4 USW Santorini Black
Don't forget though, if lifting items onto and off the rack whilst partially on the ladder, if you are right handed that will be a pig, and I think hence why ladders are more commonly on the left? If you are a leftie though, then its a bonus. North Cumbria Search and Rescue - Team Leader
Post #528312 1st May 2016 1:09pm
Birdy
France 2011 Defender 110 Puma 2.4 XS CSW Santorini Black
"I think hence why ladders are more commonly on the left"
I think it's 'cos if they were on the right the door-mounted spare wheel would bash into them!
But I had a Brownchurch roof rack/ladder which partially obscured the number plate, never had a problem with MOTs
Peter
Post #528321 1st May 2016 2:57pm
DuncanS
Yep other than the obvious rear wheel haha! Laughing North Cumbria Search and Rescue - Team Leader
Post #528359 1st May 2016 7:21pm
LR90XS2011
i think they are generally on the left so you can use them with the rear door open DEFENDER 90 TDCI XS,
Post #528441 2nd May 2016 7:39am
Nevillerover
United Kingdom 2007 Defender 110 Puma 2.4 XS CSW Sumatra Black
Spare wheel will foul if ladder is on right side. Regs are quite ambiguous and I think just says plate must be visible from the rear. Yours is.
Post #528914 3rd May 2016 9:05pm
Ladder may also foul the door if on the offside.
Post #528923 3rd May 2016 9:20pm
