Home > Puma (Tdci) > Puma Easy Clutch
dilukabey
2009 Defender 110 Puma 2.4 SW Keswick Green
Puma Easy Clutch
[img]https://www.defender2.net/gallery/albums/userpics/11849/normal_20160430_103412.jpg[/img]
Today I just noticed my mates 110 puma tdci clutch was softer than mine and when hooked up the bonnet, this is what I found. Any idea?
Post #527977 30th Apr 2016 7:00am
agentmulder
Kuwait
Someone has replaced your master with a non puma spec cylinder, but managed to create a T junction such that the sensor still works (it's usually connected via a banjo directly to the master...)
Not sure why it's rougher, other than:
> The master is a poop one and/or not specced properly in terms of amount of fluid transfer
> You've got air/crud in your line
> Slave is similarly shod
Either way, the fluid is making some extra turns, which only serves to increase surface friction - but it's probably not in the order of magnitude that you're experiencing.
Post #527979 30th Apr 2016 7:23am
Roy5695
There is a specific kit that aids the clutch, called redbooster. Made for the defender and works very well apparently, if the wifes hips get much worse ill have to have one fitted as she struggles to drive the truck at the minute.
Post #528808 3rd May 2016 4:24pm
