![]() | Home > Technical > Rear Stub Axle Gasket part number 110 Td5 ???? |
stooby do Member Since: 14 Mar 2015 Location: St. Helens Posts: 69 ![]() ![]() |
I am replacing all the seals on my rear hubs at the weekend as I'm getting a lot of diff oil dripping onto my brake disks. I have bought replacement stub axles in case they are worn as don't want to strip it down on the weekend and find out I need new ones. Does anyone know the part number for the stub axle gasket as I can't find it anywhere. The only one I can find for a 110 is FTC3649 but this is only applicable up to chassis (V)WA159961 I presume for Salisbury axle. Mine is a 2004 Td5 with the Rover axle. Any help would be muchly appreciated.
Vogler Member Since: 02 Nov 2014 Location: Brussels Posts: 309 ![]() ![]() ![]() |
A bit late, but since you didn't get an answer: I checked the list of parts that I ordered when replacing the rear hubs of our 110 Td5 with Rover Axle. I ordered gasket FTC3648
http://www.paddockspares.com/ftc3648-gaske...-axle.html Hope this helps. Greetings, Joris |
Thanks Vogler, the info I had was that FTC3648 is for a 90. I have got FTC3649 and also FTC3650, hopefully one of these will be correct!
