Home > Maintenance & Modifications > Recents Jobs, wipers and steering shaft
Chamois
2002 Defender 110 Td5 CSW Zambezi Silver
Finally managed to get round to fixing my windscreen wipers, the swept area was slowly decreasing so I knew something was up. I pulled back the dash and found that the wiper motor was wobbling around quite a lot so I check the clamp, which seemed ok. The motor still had lots of movement which didn't seem right, then I notice the rubber cover and thought I'd have a look to see what was what only to find the nut that holds the wiper pipe to the motor had come adrift. All tightened up and working perfectly.
Fitted a new lower steering shaft today and it's made quite a big improvement, the top UJ was stuffed. I'm sure 2mm at the UJ would be like 2cm at the wheel.
Front track rod a track rod end to fit next. Winter's here, thanks goodness!
Post #508488 26th Feb 2016 6:50pm
Chamois
Few more jobs to add to the list.
Steering rod and track rod end
Oil and filters
Adjust rockers
De Cat down pipe
Fix rust on rear xmember
Fit new door hinges and windscreen blocks
Get roof painted black
Thanks for starters. Winter's here, thanks goodness!
Post #522578 9th Apr 2016 8:16pm
redline
Switzerland
Is yours a Puma? Do you have a part number for the steering shaft?
Post #526376 24th Apr 2016 8:48am
Chamois
Hi Redline
I have a TD5
I got a Bearmach stearing shaft from a local LR parts store. Made a massive difference as the old one had heaps of play. Winter's here, thanks goodness!
Post #526381 24th Apr 2016 8:55am
Fatboy Slim
Wales
Tidy Thumbs Up
Post #526382 24th Apr 2016 9:02am
redline
Switzerland
Thanks Chamois! Just about to do the track-rod ends and steering shaft on my LHD, and trying to figure out if the parts are any different from the RHD ones...
Post #526386 24th Apr 2016 9:23am
