Home > Wheels & Tyres > using a smaller sized diameter and width wheel as a spare. |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6605 |
Doing the calcs, 33x12.5x15 is the equivalent of 318/72R15 in metric
Doing a comparison with 235/70R16 (Discovery size?) gives: Specification Sidewall Radius Diameter Circumference Revs/km Difference 318/72-15 229mm 419mm 839mm 2636mm 379 0.0% 235/70-16 164mm 368mm 735mm 2310mm 433 -12.3% 12% is way, way, way too great a difference for the spare to be OK with your normal tyres 1988 90 Td5 NAS soft top 2015 D90 XS SW |
22nd Apr 2016 4:39pm |
gazman Member Since: 17 Aug 2015 Location: Liverpool Posts: 652 |
thanks.
I won't carry anything and just call a breakdown service if something goes wrong. 2014 - current ..... 2003 defender td5 90 (my car) 2009 - current .... 2005 zx10r |
22nd Apr 2016 5:31pm |
Christian1402 Member Since: 17 Feb 2016 Location: Cumbria Posts: 214 |
Martin,
Sorry for hijacking but what about a 285/75/16 using a 265/75/16 as a spare? It's basically what I've got and I was hoping I didn't have to buy another tyre. There can't be much difference, half an inch in diameter? |
5th May 2016 10:01am |
pjb Member Since: 08 Apr 2009 Location: Sunny Oxford Posts: 1244 |
265 & 285 are just different widths that is not a problem as a temporary spare its only different diameters that cause a problem
Yours are both 16" spares with same 75 profile ie tyre height At least that is what I thought but I'm wrong - see below 2020 P300 HSE Last edited by pjb on 5th May 2016 10:50am. Edited 1 time in total |
5th May 2016 10:38am |
No, the tyre height (sidewall size) is different. The "75" means "75% of the width".
A 265 tyre has sidewalls of 199mm A 285 tyre has sidewalls of 214mm Specification Sidewall Radius Diameter Circumference Revs/km Difference 265/75-16 199mm 402mm 804mm 2526mm 396 0.0% 285/75-16 214mm 417mm 834mm 2620mm 382 3.7% 30mm difference in diameter, nearly 100mm difference in circumference (3.7%) 1988 90 Td5 NAS soft top 2015 D90 XS SW |
5th May 2016 10:45am |
oops
I've been wrong for so many years 2020 P300 HSE Last edited by pjb on 5th May 2016 10:48am. Edited 1 time in total |
5th May 2016 10:47am |
Birdy Member Since: 07 Oct 2011 Location: Côte d'Azur Posts: 865 |
Not quite true, in the sense that the "75" is a percentage of the tyre's with, so in this case the overall diameter will be about an inch less. Whether or not that's of any significance I'll leave to the experts.
Peter Edited to add: Martin beat me to it! |
5th May 2016 10:48am |
