Home > Puma (Tdci) > .. |
EssexMatt Member Since: 19 Apr 2016 Location: Essex Posts: 5 |
19th Apr 2016 12:33pm |
EGR isn't blanked at the moment. It self cleans when I turn ignition off...I can hear it clearly chirping. I have EGR shut off in map. Think I may need to blank?
19th Apr 2016 4:24pm |
Plume of white smoke on startup when cold is normal, they all do that and you don't need to worry.
As for the clouds when you pulled away, I don't know. Is that just the once? |
19th Apr 2016 8:57pm |
Jukathy Member Since: 25 Jan 2015 Location: Berlin Posts: 170 |
Unburnt diesel.
Could be the injectors or the injector seals. Have read that in a German forum before. Copper seals for injectors cost about £10 each. Much luck. P.S. babelfish is your friend: http://www.blacklandy.eu/blboard/forum/sho...m-Anlassen |
19th Apr 2016 9:30pm |
tomdaprince Member Since: 23 Feb 2015 Location: IJmuiden Posts: 54 |
Just as precaution I would have all four injectors tested by a certified diesel specialist. Regarding EGR which could be unrelated in this issue, I would definitely get it blanked. Source of many issues and is not contributing to your engines performance, just an emissions thing. EGR is just letting exhaust gasses back into inlet which makes no sense what so ever.
20th Apr 2016 7:38am |
Thanks for the responses.
I will blank EGR and get injectors tested. Still doesn't quite solve my heater not blowing very hot compared to a week ago Might try bleeding the hose going to the heater valve. |
20th Apr 2016 9:51am |
There is some more to EGR blanking than with the old engines. You will have to have the MAP adjusted to otherwise You will get the MIL lite on. Contact your tuning supplier, he will be able to assist you with this.
heaters sometimes have a life of their own, could start by checking the heater cables under the hood, could be that one of those came loose. Start with the easy stuff and then work towards the harder stuff. |
20th Apr 2016 9:53am |
Thanks for that. The remap has turned the EGR off so it shouldn't throw a warning.
I checked cables and they were fine, will see how it goes after checking for air in hoses |
20th Apr 2016 11:55am |
Quick update on heater....now working as usual, usual being that it blows very hot air no matter what setting its on
Didn't do anything to fix it, it just decided to work!! |
20th Apr 2016 3:47pm |
