Home > Technical > TD5 Headlights |
Go Beyond Member Since: 30 Jan 2012 Location: Headcorn, Kent Posts: 6678 |
Almost certainly the headlight switch
17th Apr 2016 2:48pm |
300TDi CSW Phil Member Since: 03 Apr 2016 Location: Bracknell Posts: 750 |
Had a similar problem with my 300Tdi (I'm pretty sure the switch in question is the same with a different connector). It turned out to be the contacts in the Stalk switch that controls the main beam and flash. One of the contacts had become loose and floated just enough to break contact.
Worth having a look there. 1995 300 Tdi Epsom Green - It's a keeper. Wide Track Sankey- In bits- Gone to a new home M0XQS |
17th Apr 2016 2:52pm |
luckygoldstar Member Since: 23 Jan 2015 Location: south west Posts: 41 |
I took out the switch unit ...and it looks brand new..had a good look at the contacts ?
17th Apr 2016 4:00pm |
chopcat Member Since: 11 Sep 2012 Location: Pembrokeshire Posts: 412 |
switch is the No1 cause if you are running the full amps through it.
check by bypassing it and shorting the contacts .....after checking which are which with a meter CC |
17th Apr 2016 6:59pm |
Bev Member Since: 03 Apr 2013 Location: Perthshire Posts: 267 |
I had the same issue on one of my trucks. It turned out to be the connectors on the loom plug just before the stalk. The multi plug was white and sat just below the main column and could easily be found by tracing the feed back a few inches from the stalk once the column shroud is removed.
The cause was still the same- too much current flowing through and the pin for the main power feed had corroded and failed under load. Takes two minutes to bypass though with suitable cable 2002 Td5 | 90 County Station Wagon | Oslo Blue 2006 Td5 | 90 County Station Wagon | Tonga Green (Gone ) 2002 Td5 | 90 County Station Wagon | Zambezi Silver (Gone) |
17th Apr 2016 8:38pm |
will have a look...am 260 miles from home now...and I forgot to pack the socket for the steering wheel!
17th Apr 2016 9:54pm |
