- You are currently viewing DEFENDER2.NET as a guest - Register to take part or Log In
Touchwood
Defender double cab central locking | |
Hi all just after some advice. Currently building a 1987 127 double cab and just purchased some new tdci take off doors for it which are fitted with central locking in all 4 doors. Is there a simple way of wiring them up. Do I buy an aftermarket setup or can I use a genuine set up. Was planning on putting a fancy pants Alarm on it so any recommendations would be great.
Thanks in advance
16th Apr 2016 8:21am |
Romadog
On a Td5 there is a loom that runs underneath back of seatbox between rear doors and into fusebox area under drivers seat to join the main loom back to alarm box. The front doors just run into door posts and up into engine bay, then back through bulkhead to rear of dash to Alarm box ecu.
16th Apr 2016 5:45pm |
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
