Home > Technical > Dixon Bate shocklink
ChrisCM
United Kingdom 2010 Defender 110 Puma 2.4 SW Santorini Black
Hi,
I have obtained a Dixon Bate shocklink.
Does anybody know if this will fit a standard Dixon Bate adjustable height coupling back plate?
I want to use the Shocklink on 2 defenders and thought that the best plan would be to fit the shocklink back plate on one Defender and an adjustable height coupling backplate on the other thus making everything interchangeable, but of course this depends on them being the same size with the same hole configuration hence the question!
Chris 2010 Defender 110 Station Wagon, Santorini Black.
Post #524271 15th Apr 2016 4:59pm
leeds
Hi Chris, we have a shock link fitted to one of our Defenders except that one is not at home at this moment in time.
The fixing plate is attached to the back of the shock link so all you do is pull the two pins out to transfer it between Dixon Bates towing equipment.
Brendan
Post #524301 15th Apr 2016 6:53pm
ChrisCM
Hi Brendan,
Yes, that's what I want to do, just wasn't sure whether the fixing plates for the Shock link and the adjustable hitch were the same width and the locating holes had the same pitch to enable interchangeability between the shocklink and the adjustable hitch carrier plate.
Post #524335 15th Apr 2016 8:59pm
ARC99
United Kingdom 2008 Defender 110 Puma 2.4 USW Cairns Blue
I have the Shocklink and it matches the adjustable plate on my Land Rover supplied tow bar. Don't make old people mad.
We don't like being old in the first place,
so it doesn't take much to Censored us off.
Richard
Post #524429 16th Apr 2016 9:54am
ChrisCM
So, looks like it will fit, I believe the LR adjustable hitch is made by Dixon Bate.
Post #524641 16th Apr 2016 11:03pm
