![]() | Home > Tdi > No charge |
The Hulk Member Since: 13 Apr 2016 Location: Aberdeenshire Posts: 81 ![]() ![]() ![]() |
I'm pretty certain the 90 isn't charging. Starting performance hasn't been great so I replaced her battery with a fully charged one and all was good for a week or so. Now it's going the same way. The battery that came out has been on charge for several days and is now good.
The clincher was using an air compressor to check the tyre pressures. The compressor normally sounds good when the engine is running but on the 90 it sounded sick - and it sounded exactly the same when I switched the engine off. On the 110 the compressor sounded normal with that engine running but sick with the engine off. Checking the 90 with a meter gave a consistent 13ish volts at the alternator regardless of whether it was running or not. It's possible that everything just needs a clean? There's no other evidence of the alternator failing; no strange noises etc. Is there a regulator in the back of the alternator and is it possible that's all that's required to be replaced? Mid Life; Live It! Ongoing thread: http://www.defender2.net/forum/topic45697.html 110 300Tdi Utility (Hulk) 90 300Tdi SW (GF's Tank) |
Running you should be getting around 14.4v from the alternator. 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html
Browny90 Member Since: 20 Jul 2015 Location: Derbyshire Posts: 183 ![]() ![]() ![]() |
you should certainly notice a change in voltage between the engine running and not.. It sounds like you alternator has packed up, but worth checking all conections and cleaning etc..
pop into a halfrauds, they will do a free battery check normally where they use a bit of kit that checks it under load etc.. it will tell you battery and charging health etc.. My 1986 90 is currently on a full rebuild, with new chassis, Paint etc.. Very much a hybrid, TD5 Chassis, tub & bulkhead with a 200TDI and LT77 GB Painted in Stornoway Grey ![]() |
jeffersj Member Since: 23 Jan 2015 Location: Near Preston Posts: 431 ![]() ![]() ![]() |
I am assuming that drive belt is correctly adjusted and not slipping slightly? Jeff
Ex 1968 Series 2A Ex 90 TD5 Ex D3 Ex D4 |
Yes, everything running as it should, and the battery is good.
I'll probably remove the alternator and see what's inside. I just wondered if there was a separate regulator which could be tested first? Mid Life; Live It! Ongoing thread: http://www.defender2.net/forum/topic45697.html 110 300Tdi Utility (Hulk) 90 300Tdi SW (GF's Tank) |
if its an A127 Alt link is good parts pic
http://www.jcrsupplies.co.uk/products/ALTE...TYPE_.html Last edited by dorsetsmith on 16th Apr 2016 11:00am. Edited 1 time in total |
Does de charge light in the instrument panel come on with ignition, and does it go out when the engine is running? Cheers, Vincent
1959 Polynorm 1/4 Ton Trailer, Olive Drab Green (sold) 1970 M416 Military Trailer (Camping Trailer Conversion), Epsom Green (sold) 1975 Series III 88 V6, Light Green (sadly sold) 1996 Defender 110 CSW 300 Tdi, Epsom Green (sold) 2000 Freelander 1 TD4 3-drs, Silver (sold) 2006 Freelander 1 TD4 5-drs Facelift Automatic, Tonga Green (sold) MySite |
Good point! The battery warning light is on with the ignition but goes out immediately on starting. Surely it should be illuminated if the alternator isn't charging? Is there any reason why it wouldn't if the bulb works? Mid Life; Live It!
On with ignition and then off with charging is OK, so the bulb is working and the alternator gets field current.
If you measure the voltage at the alternator and it is less than approx. 14.4 V, the regulator or diodes may by gone. If no loose connections or faulty wiring, I would suggest to have the alternator tested by a specialist. Cheers, Vincent 1959 Polynorm 1/4 Ton Trailer, Olive Drab Green (sold) 1970 M416 Military Trailer (Camping Trailer Conversion), Epsom Green (sold) 1975 Series III 88 V6, Light Green (sadly sold) 1996 Defender 110 CSW 300 Tdi, Epsom Green (sold) 2000 Freelander 1 TD4 3-drs, Silver (sold) 2006 Freelander 1 TD4 5-drs Facelift Automatic, Tonga Green (sold) MySite |
This is covered on another thread but it's more relevant here so I'll make the point for others looking...
The problem was not a duff alternator but a POOR EARTH connection between the battery -ve and the gearbox. A very simple fix with a socket set and some electrocal contact cleaner (or WD40 if that's all you have). The Earth cable is about 20" long and runs from the battery to the gearbox via a chassis clamp. Make sure these connections are good or you can experience all sorts of problems. I was going to buy a new alternator this weekend but it would have made no difference and would also have shown to be not registering a charge voltage. I suspect the lack of a good earth from engine to battery had stopped the alternator from doing its job properly? Mid Life; Live It! Ongoing thread: http://www.defender2.net/forum/topic45697.html 110 300Tdi Utility (Hulk) 90 300Tdi SW (GF's Tank) |
