![]() | Home > Wheels & Tyres > Spacers |
I can't do better than what he says ![]() |
discomog Member Since: 09 May 2015 Location: Notts/Lincs Border Posts: 2528 ![]() ![]() ![]() |
You'll not find a better explanation than that.
![]() Mini Countryman Cooper S Morgan Plus 8 |
Def Junkie Member Since: 30 Dec 2013 Location: Somewhere in Paradise Posts: 79 ![]() |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17432 ![]() ![]() ![]() |
There's nothing that is factually incorrect in that video, but what it lacks is contextualisation.
Generally people fit spacers as part of a wheel and tyre upgrade, and changing the tyre size is likely to have far more effect on the vehicle than fitting spacers. Some effects of spacers can be counteracted by changes to tyre dimensions, for example the increase in scrub radius caused by a spacer may be neutralised by an increase in tyre diameter. In practical terms, you are unlikely to notice any significant effects if you fit 30mm spacers. If you fit wider, then you will notice a difference. If you fit, say 285/75 tyres in place of 235/75 you will notice more differences in handling than you will from fitting 30mm spacers and not changing the tyres. The old wives' tale that spacers will cause your wheelbearings to wear out is, frankly, rot, since the effect of a 30mm spacer on a wheelbearing is insignificant. Carrying a passenger will load your wheelbearings more than a 30mm spacer. If you were to fit 75mm spacers, expect trouble, but a sensible spacer will be well within the designed operating parameters of the hub. Not mentioned at all in the video is possibly the biggest consideration of spacers, namely the physical strangth of the spacer itself. You would be foolinsh to fit, assuming you could find one, a spacer less than 30mm in thickness, because it isn't thick enough to safely accommodate the bolt-heads for the new studs nor the nuts for the old ones (spacers less than 30mm usually are shims that use the existing studs, whcih is again not a good idea). Spacers thicker than 30mm will start to take you into the adverse-effects territory. It is also the case that the effects on steering and suspension geometry will be the same if you were to fit a 30mm spacer with your existing wheel, or a wheel of the same width with 30mm lesser offset. Some of the effects that the chap in the video mentions are specific to IFS and will not manifest themselves on a Defender with its beam axle anyway. |
As Blackwolf says the video is factually correct but the effects of spacers on the geometry and bearing life is so minimal that it's not even worth considering. If you like the look of the vehicle with spacers and don't mind a bit of mud splatter then go for it. Come to think of it, if you drive a Defender the last thing on your mind should be worrying about a bit of mud! Defender 90XS SW
RogerG Member Since: 02 Sep 2014 Location: Exeter Posts: 24 ![]() ![]() ![]() |
I fitted 30mm terrafirma alloy spacers to improve the turning circle on my 110. Adjusted the lock stops to 22mm clearance - same width as a roll of insulating tape which makes it easy to set up - just wind the stops in/out until it hold the roll between the tyre and tie bar. Made a huge difference as I can now get out of the drive and onto the lane in one instead of having to take a shunt, tighter than my old 90. Mud spatter taken care of by fitting the Gwynn Lewis mudflap kit on the front and the MUD UK spats on the rear.
Appreciate the advice guys. Spacers fitted
JOW240725 Member Since: 04 May 2015 Location: Suffolk Posts: 7906 ![]() ![]() ![]() |
I've done the same as RogerG (Terrafirma spacers and Gwyn Lewis mudflaps) and agree the turning circle is significantly improved, almost car like! Big improvement.
LoveTheMud Member Since: 19 Feb 2015 Location: Weybridge Surrey & Pontefract West Yorkshire Posts: 411 ![]() ![]() ![]() |
not sure if this is even possible or not but, have any of you with the 30mm spacers fitted, noticed or likely to notice the tyres rubbing on the arch? I'm imagining off road use here and cross axle maneuvers... I'm going to get a set but will be doing some offroading so wanted to get peoples experience / opinion
I also won't fit spacers,,,with a long enough lever I can snap a Defender axle in two,(Archimedes ,AD340)
For quite a while I ran 285/75 BFG KM2s on Boosts on 30mm spacers and never had any contact issues. I now run 255/85 BFG KM2s on ET15 Blindos without spacers, and these had contact issues on the front lower corners of the rear arches, nothing serious though, and easily rectified (invisibly) in a few minutes with a sharp knife. I have to admit that I was surprised since the outside diameter of the tyres are very similar, the combined effect of the narrower section and reduced positive offset should have put the outside corner in about the same place. You wouldn't be able to run tyre chains on either of these unless you either modify the suspension or accept that the chains are going to rip your bodywork apart. |
Pickles Member Since: 26 May 2013 Location: Melbourne Posts: 3785 ![]() ![]() ![]() |
We are in the minority here mate, but neither would I. They are illegal in Aus. Pickles. |
That surprises me Pickles, there are people that run spacers on 70 series Cruisers to sort out the rear track issue.
Maybe that's why people change from spacers to wheels with an offset that mean you have to have two spares. |
I'm not familiar with the issue that you speak of, but yes, they've always been a No No in Aus, going back to the days of our early model Holdens. It's as Jimbob says, along the lines of "Archimedes". Not saying of course that some don't fit 'em in Aus, but if there was an issue with a claim surrounding the area where they are fitted, there would more than likely be an issue with the insurer.
Pickles. |
