![]() | Home > Puma (Tdci) > Holding revs between gear changes |
ARC99 Member Since: 19 Feb 2013 Location: North Yorkshire Posts: 1831 ![]() ![]() ![]() |
I thought that this was just one of those thing, some do it all the time , others don't and some do some of the time.
Mine will do it one day then has a break of 3 or 4 months , or it does it for a week and then has a break. I have spoken with main dealers and Independent garages they all know about it, do not know what causes it or how it can be stopped. Don't make old people mad. We don't like being old in the first place, so it doesn't take much to ![]() Richard |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17602 ![]() ![]() ![]() |
2.2 is known for this but not the 2.4.
It is indeed possible that the clutch pedal switch is the culprit, and it is at least quite easy to test. |
Eduardo Member Since: 28 Aug 2008 Location: RegiĆ³n Metropolitana Posts: 2110 ![]() ![]() ![]() |
In fact ours are developinng the opposite. Some times when the gear change, revs goes up for 1 sec and then drops...
Until now doens't means any problem. I will check the clutch pedal switch (I have to change the cylinder anyway) Cheers! Eduardo MY 2007 110 SW PUMA 2.4: Big Fog of 64' MY 1994 Jayco 1207 Folding camper: "El Tremendo" ![]() Click image to enlarge |
GAZ59 Member Since: 10 Feb 2015 Location: DARWIN Posts: 3 ![]() ![]() ![]() |
I have the same problem and also no solution from the people who should know. Iam going to try changing both clutch and brake switches when they turn up. Have thought this could be linked to the anti stall system??
Thank Garry |
ChrisJ Member Since: 12 Nov 2013 Location: Warwickshire Posts: 231 ![]() ![]() ![]() |
My 2.2 has done this from new (year old nearly). Does it everyday mainly between 3rd and 4th. I've just learnt to live with it.
agentmulder Member Since: 16 Apr 2016 Location: Outer Space Posts: 1324 ![]() ![]() |
Check the pressure sensor on top of the clutch master cylinder. I know (well, 'heard') that when the clutch is depressed it sends a signal to the ECU to reduce RPM... Could be something there
excossack Member Since: 22 Feb 2012 Location: North West Posts: 5884 ![]() ![]() ![]() |
Thanks for the replies, I will pass on the info 1999 Defender TD5 110
DaftOldGit Member Since: 20 Sep 2015 Location: London Posts: 52 ![]() ![]() |
I had a faulty clutch switch on my 2.4 Puma. The ECU thought that the clutch was constantly depressed and therefore wouldn't allow the revs to exceed 3000rpm. It didn't maintain the engine speed the way you're describing though.
Incidently, I found that the switch for the Puma and for the TD5 are opposite throw (one is normally open going closed, the other is normally closed going open), so make sure you have the right one. |
Issue resolved - by replacing the clutch switch.
Thanks all. 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
