Home > Td5 > max tune
foxing
Wales
max tune
how far could a td5 be tuned?
atb paul
Post #520455 3rd Apr 2016 8:39am
Disco_Mikey
Scotland 2009 Defender 110 Puma 2.4 DCPU Keswick Green
Depends how deep your pockets are Whistle
220+ bhp is achievable, and IIRC, there is/was a few up around 240bhp
Post #520459 3rd Apr 2016 8:52am
foxing
Wales
i have a stage 4 alive at about 220 bhp,just wondering how much further i could go if money were not an issue.
atb paul
Post #520488 3rd Apr 2016 10:57am
Bps
Sounds like with a stage 4 you've got most of the bolt on bits sorted. Blue printed engine, ported and polished will see some some gains. Did alive custom map it ? if not some gains may be had there
Money no objet go for an engine change om606 conversion, LS v8, super chargers, nitrous, 3.2 etc
Post #520492 3rd Apr 2016 11:06am
foxing
Wales
no the map was done by rdt tuning in Bristol.So maybe a trip up to alive is in order
atb paul
Post #520496 3rd Apr 2016 11:36am
miker
Mine's currently standard bar an EGR delete. How far can you go without changing loads/loads of cost?
I guess I/C, exhaust, remap and that should see 150-170?
Reliability is very important, and reliability carrying a full load of people + a trailer!!
Post #520497 3rd Apr 2016 11:42am
Disco_Mikey
atb paul
RDT are an Alive agent already Thumbs Up
No doubt there will be a few BHP to be found with a map fine tuned on the dyno though
Post #520503 3rd Apr 2016 12:19pm
110MGD
2001 Defender 90 Td5 CSW Epsom Green
EGR delete centre box removed and a sports air filter for me plenty power Thumbs Up
Was looking at tuning but as I have a pre 2002 I'd need to change my ECU and my original transmission is getting tired with over 110k miles - functioning well still but remapping and a sports intercooler and 30-60bhp and it'd be knackered pretty quick I reckon. 2001 Td5 CSW (weekend and snow mobile) Plenty of lights, M/T tyres EGR delete, roofrack, swing away wheel carrier, snorkel.
2016 E220 CDI Night Edition Estate
2014 VW UP!
2x D3 and 1x D4 GONE
Post #520653 3rd Apr 2016 7:50pm
derbywill
England 2005 Defender 90 Td5 XS CSW Java Black
Propane injection? there was a company used to do it for td5.
Regards
Will 2005 90 XS
1954 86'' Series 1 tilt
1968 88” 2A 200tdi
2002 110 Hardtop
Post #520717 3rd Apr 2016 10:21pm
K9F
foxing wrote:
...... how much further i could go if money were not an issue. atb paul
Never mind the propane injection. Forget tuning too, 475BHP plus. Go to JE Motor Works and see what they could do for your TD5 if the chassis etc. is up to it, money is no object and you've a spare 70-80k lying about in loose change and a sound vehicle to carry the mods out on. Engine transplant would be your best bet. Why are you trying to eak more out of it if you're sat at 220 already? Brakes etc. would also perhaps need to be given upgrade considerations too?
http://jemotorworks.co.uk/
Whistle If you go through life with your head in the sand....all people will see is an ar5e!!
Post #520755 4th Apr 2016 8:09am
pjb
I'm not knocking you Foxing but why do you want more power ?
I like quick cars but never really wanted the defender to be that quick car, I love the defender as it is, nice to have it a bit quicker say 150bhp, but not sure I would want a car the size weight & engineering of a defender to have the performance of an RS3 Thumbs Up
I must be getting too old as I often look on here and wonder why do that to a defender Whistle 2020 P300 HSE
Post #520761 4th Apr 2016 8:41am
Hufflepuff
For a matter of interest, how fast if a td5 with 220hp, and how smokey?
I'm running Alive's stage 2 at the moment (Intercooler, exhaust, EGR delete, remap and that pressure sensor reduction box thingy), but they kindly turned down the tune at the top end due to the amount of smoke it was putting out.
Its still smokey under full load above 2500rpm, which they couldn't get to the bottom of (I should say it was only a brief look at the Billing show last year), bascially it wasn't flowing enough air, and changing the MAF didn't help.
I would guess I've got a solid 150-170hp which is fine for a Defender, and it will happily cruise at 70mph now, I just wish it didn't smoke as much.
Post #520819 4th Apr 2016 11:39am
Likeomg
try a bit of 2 stroke oil in the fuel, i have a stage 4 2.4 and it smokes a little (nothing bad at all) but the oil helps with a cleaner burn
theres 100's of threads on here which oil to use, I'm pretty sure its organic something or other...
Post #520822 4th Apr 2016 11:52am
There's a certain member on here, who 200+ bhp simply wasn't enough from a td5, so, money not being an object..
has gone for the 400bhp OM606 route Thumbs Up Thumbs Up
Believe me, that thing will be awesome!!
But yeah, as said above, if I want speed, I just grab the keys to Mrs Greeni's estate!!
Post #520827 4th Apr 2016 12:00pm
Likeomg
6pot also has a semi ls3 build thread... not very well updated hopefully he will sooner or later Shocked
Post #520829 4th Apr 2016 12:01pm
