Home > Td5 > Ignition fed live
Loz2286
Ignition fed live
Is there a convenient ignition fed live in the engine compartment that can be used to support various accessories?
Is it safe to take a feed from the back of the cigarette lighter? 1999 Td5 110 CSW
1961 Series 2 88 LPG
Post #520166 2nd Apr 2016 12:28am
Screbble
The answer in theory to both questions is yes
BUT
It does depend on what you are aiming to do?
As always, the correct fusing, cable size and retaining the integrity of any circuit you intend to connect into are all considerations.
I'll try and dig out some wiring diagrams that may assist, although I suspect another forum member will beat me to it and provide an electronic version!
Best of luck Thumbs Up
Post #520183 2nd Apr 2016 7:18am
4RF RDS
Canada 2000 Defender 110 Td5 XS CSW Epsom Green
 2010 Range Rover MkIII Autobiography Super Charged (Idris)
2003 Range Rover Mk III (Desmond FitzWilliam)
2000 Defender 110 CSW TD5 (CTX)
1992 Range Rover Classic (Lizzy)
1972 Series III 300 Tdi (Stanwood)
1967 MGB GT
Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats.
H. L. Mencken (1880 - 1956)
Post #520288 2nd Apr 2016 2:59pm
Loz2286
Ta muchly. 1999 Td5 110 CSW
Post #521360 5th Apr 2016 9:48pm
Mo Murphy
Only use one to switch a relay. It is not a good idea to run additional circuits off existing wiring as they are sized and fused for their original purpose.
A relay will only draw milliamps for switching so you could take a feed from the power socket, then you can run power to the relay from the battery and out into a fuse box where you can distribute it to the various additional circuits you wish to add.
HTH
50 Shades of Pennine Grey
Post #522647 10th Apr 2016 12:49am
